Python Programming Basics: IDLE vs Command Line
  • Context: Python
  • Thread starter Thread starter DrummingAtom
    Python
The discussion centers on the differences between IDLE and command line interfaces in Python programming, as well as considerations for learning Python on different operating systems, specifically Windows versus Linux/Unix.
  • One participant asks about the difference between IDLE and the command line, expressing confusion as a beginner.
  • Another participant explains that IDLE is a Python development environment that includes an interactive command line, while the operating system's command line (like Bash) is used for OS commands.
  • A different participant elaborates that the Windows command line allows for running programs and navigating directories, while IDLE provides immediate execution of Python code.
  • Several participants raise questions about whether learning Python on Windows is worthwhile compared to Linux/Unix, with some suggesting that the choice of platform should depend on personal comfort.
  • One participant references a viewpoint from ESR about learning programming in a closed-source environment, suggesting that it may limit learning opportunities, while sharing personal experiences of transitioning from Windows to Linux.
Participants express differing opinions on the value of learning Python on Windows versus Linux/Unix, with no consensus reached on which platform is superior for learning.
Some participants mention the potential limitations of learning in a closed-source environment and the applicability of skills across different operating systems, but these points remain open for further discussion.
DrummingAtom
I just started learning programming and am a little confused about the difference between IDLE and the "Commands Line." What's the difference?
Technology news on Phys.org
IDLE is a Python development environment, which INCLUDES a command line (that's the window with the 3 arrows >>> that you can type Python commands into), as well as other utilities like a debugger and a text editor. There is another kind of command line your book might refer to, the operating system's shell, which uses some other language like Bash (not Python), and can be used for things like running programs and moving files around.
If you are learning from a book and are on windows, then likely what they mean by a command line is the prompt you get if you go Start|Run, type in cmd and click ok. This would then give you a black command line that you can run programs from (including navigating to your python script directory and running scripts using python <script>). This gives you complete access to OS commands but no access to python code without running a python script or just running python to start an interactive session.
IDLE on the other hand has as part of it and interactive python interpreter. This let's you type in lines of python code and it will execute them immediately (or in the case of functions and classes, they will be defined as soon as you have finished the block of indented code). This gives you complete access to the python library but no access to the OS commands without using a system call of some description.
Thanks for the answers. Another question is should I be learning Python in Windows or Linux/Unix? The tutorial I'm using explains both operating systems. Am I wasting my time learning the Windows side?
Other than maybe some of the software you use to develop it, Python should be the same on all operating systems as far as I know. Do it on whatever platform you feel most comfortable on to start with and everything you learn will be someday applicable to other operating systems as well.
Did you read ESR's how to be a hacker? Well he states that learning to hack under a closed source os is like learning to dans in a body cast. That is quit true in a way because you need to read some source to learn good programming skills but I started in windows and it was'nt to bad but I am now more pleased with my penguin ;-)
How to be a hacker http://catb.org/~esr/faqs/hacker-howto.html
and ESR's home http://catb.org/~esr/
Here youl find some good stuff to put you on the right track.
Good luck!
