Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Number Theory
Reply
image unknown primes less than largest known prime? Share It Thread Tools Search this Thread image
Old Apr27-09, 03:56 PM                  #1
SW VandeCarr
SW VandeCarr is Offline:
The largest known primes for some time have all been Mersenne primes. Can it be shown either that there may exist or cannot exist unknown primes less than the largest known prime?
Old Apr27-09, 04:14 PM       Last edited by mgb_phys; Apr27-09 at 07:17 PM..            #2
mgb_phys
Physics Guru 2008
mgb_phys is Offline:
Recognitions:
Homework Helper Homework Helper
Re: unknown primes less than largest known prime?
I'm not sure you can even prove that there aren't other Mersenne primes between the those found.
Old Apr27-09, 06:11 PM                  #3
CRGreathouse
CRGreathouse is Offline:
Recognitions:
If you're talking only about other Mersenne primes, mgb_phys answered it: we have no idea. But to answer your literal question:
There are more than 1012978181 primes* beneath the largest known Mersenne prime. If storing each prime takes 1 bit, there has not been enough storage media produced on Earth through all history (hard drives, DVDs, clay tablets) to hold all these primes.
So yes, there are unknown primes beneath the largest known prime.
* In particukar, there are between 1.05901756822452 × 1012978181 and 1.05901756822453 × 1012978181 primes in that range, thanks to Pierre Dusart's tight bounds on pi(x).
Old Apr27-09, 07:18 PM                  #4
mgb_phys
Physics Guru 2008
Recognitions:
That you can even calculate such a number is truly amazing!
Old Apr28-09, 12:39 AM                  #5
SW VandeCarr
Thanks GR Greathouse.
If I wanted to enumerate the primes over some tractable interval less than the largest known prime , would it be any easier given that at least one prime greater than the upper bound of the interval is known?
Old Apr28-09, 01:04 AM                  #6
CRGreathouse
Recognitions:
No, it would be just as hard. There's no good way to use that information.
Old Apr28-09, 08:49 PM       Last edited by SW VandeCarr; Apr28-09 at 08:56 PM.. Reason: added word "all"            #7
SW VandeCarr
I appreciate your patience with me. Just one more (two part) related question:
If I wanted to construct an unbroken sequence of all primes up to some prime p', would this limit be determined only by the limits of computability (brute force and/or algorithmic)? Is there any information regarding about what this limit might be?
Thanks in advance.
Old Apr28-09, 09:18 PM                  #8
CRGreathouse
Recognitions:
I don't mind answering your questions.
I don't understand what you're asking. But practically, if you want to make a huge list of primes, the issue you'll run into is storage: the memory needed for an efficient search (say, at least 20 * sqrt(n)/log(n) bytes to search up to n), and the hard drive (or whatever) space to keep the primes you find (say, 16 * n / log(n) bytes to store the primes up to n, or an eighth that amount for just the differences). So if you wanted a list of primes up to 10^20, you'd need several million terabytes of hard drive space (tens of millions unless you just store the differences).
Old Apr28-09, 10:39 PM                  #9
CRGreathouse
Recognitions:
1)I'm trying to confirm that all primes up the largest known prime (or any arbitrarily large prime (p')) are in principle computable (Turing definition).
They are.
2) Practically there is always a lot of interest in new largest prime, but none (as far as I can tell) as to the longest unbroken sequence of primes from 2 to p' . It seems such lists this would have utility for codes, "random" sequences and simply examining the statistical properties of such sequences. For example, do we know the first 10^6 or 10^7 primes?
There are algorithms that, given enough memory, can compute primes up to n faster than iterating through 1, 2, ..., n. So storage becomes the limiting concern there. You could fill a 250 GB hard drive with primes, but what then? It's often faster to generate them and use them on the fly anyway -- don't bother with the (slow) hard drive.
Old Apr28-09, 10:50 PM                  #10
SW VandeCarr
They are.
Thanks for your answers CRGreathouse. That's what I'll do.
Old Apr28-09, 10:52 PM                  #11
CRGreathouse
Recognitions:
May I ask what your application is?
Old Apr29-09, 12:14 PM                  #12
SW VandeCarr
I'm interested in the statistical distribution of primes as it relates to some interesting research in self-organizing processes. There's a number of papers on the net regarding this. I'm a retired epidemiologist.
Old Apr30-09, 08:21 PM       Last edited by ramsey2879; Apr30-09 at 08:28 PM.. Reason: power e.g. ability to list more and in less time            #13
ramsey2879
ramsey2879 is Offline:
They are.
Just out of curiosity and possibly to help the originator of this thread, can someone point to a source for such a list generating algorithm. I know of prime lists of the first n primes, n = 10,000 or lower are the typical lists of primes that I have seen, but as to the quickest or most powerful list generator, I have no idea of where to look.
Old May1-09, 12:17 AM                  #14
CRGreathouse
Recognitions:
The Sieve of Atkin is the asymptotically fastest method I know. Bernstein has an excellent implementation on his site.
Old May2-09, 06:19 PM                  #15
Count Iblis
Count Iblis is Offline:
Recognitions:
Isn't it easier to use the formula by Riemann that gives an exact formula for pi(x) as a series involving the zeroes of the Riemann zeta function?
Old May2-09, 06:23 PM                  #16
CRGreathouse
Recognitions:
Not if you want an exact answer.
image image
Reply
Thread Tools
Similar Threads for: unknown primes less than largest known prime?
Thread Thread Starter Forum Replies Last Post
NEED HELP WITH HOMEWORK No largest prime number msminnie Precalculus Mathematics 6 Oct2-07 10:04 PM
A formula of prime numbers for interval (q; (q+1)^2), where q is prime number. Victor Sorokine Number Theory 0 Jul21-05 03:37 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
