Centrifugal force around planets
The discussion centers on the relationship between centrifugal force and gravity in the context of planetary orbits. It establishes that centrifugal force, experienced when an object is rotated, is a result of tension in the rope due to electromagnetic interactions at the atomic level. In contrast, gravity uniformly affects all atoms of a planet in orbit, resulting in no measurable tension or displacement. The conclusion drawn is that while centrifugal force is perceived in rotating systems, it does not manifest in the same way during orbital motion due to the uniform acceleration of gravity.
  • Understanding of centrifugal and centripetal forces
  • Basic knowledge of gravitational forces and their effects
  • Familiarity with electromagnetic interactions at the atomic level
  • Concept of inertial frames in physics
  • Explore the principles of centrifugal and centripetal forces in rotating systems
  • Study the effects of gravity on atomic structures in planetary orbits
  • Investigate the concept of fictional forces in physics
  • Learn about local inertial frames and their implications in classical mechanics
Physics students, educators, and anyone interested in understanding the dynamics of forces in planetary motion and the distinctions between centrifugal and gravitational forces.
Cemre
Hello,
When I thought about centrifugal force, gravity came into my mind...
When we tie a rope around a ball and rotate it in the air, rope gets some tension ( small displacement between atoms of rope ) and we feel this as centrifugal force. This force occurs because we apply an electromagnetic force to the electrons of the atoms around the ball by the electrons of the rope. but we don't apply the same force to inner atoms of the ball so inner atoms tend to go slightly outwards from the center of the ball and cause a small displacement withing the ball. it is that displacement that we feel as tension and centrifugal force. ( correct me if I am wrong... )
But things differ with gravity. gravity goes and reaches to ALL the atoms of a planet when it is in orbit. and gives every atom the same acceleration ( tidal effects ignored ). orbiting a planet is like a continuous free fall. if every atom gets the same acceleration, distances between the atoms will not change and therefore we won't be able to measure any tension on the planet.
So my question is; do we really feel an outwards centrifugal force when we are in orbit?
That's centripetal force. It acts through the rope, and is different from gravity. It's simply a force.
Centrifugal force acts on every single bit of matter, exactly like gravity. Both, gravitational force and centrifugal force, are fictional forces. They vanish if you calculate things in a local inertial frame, where F=ma.
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 23 ·
  • · Replies 41 ·
  • · Replies 22 ·
  • · Replies 93 ·
  • · Replies 51 ·
