Integrating to find volume of an unusual shape
The original poster attempts to calculate the volume of a shape formed by revolving a rectangle and a triangle around a parabolic curve. The problem involves understanding the relationship between three given parabolic curves and how they define the volume of the solid created by this revolution.
  • Participants discuss the need for clarification on the original poster's description of the shape and the method of revolution. Questions arise about the nature of the parabolas and their intersections, as well as the specific geometry of the shapes involved.
Some participants express uncertainty about the original poster's situation and request additional information, such as a figure, to better understand the problem. There is no explicit consensus on the approach to take, and the discussion remains open-ended with various interpretations being explored.
The original poster mentions a need for an accurate method or better approximation for calculating the volume, indicating a sense of urgency. The discussion also reflects on the age of the thread, suggesting that responses may be limited due to the original poster's inactivity.
brandy
Member warned about not using the template
is there an exact way to calculate the volume of a shape where one shape is revolved around a parabolic curve (obviously with limits).
i don't know much about this stuff but I am pretty sure u need to integrate it.
the shape revolved is a rectangle (vertical) with a triangle connected at the vertices
for a birds eye view there are 3 (given) parabolic curves. the area between the top and middle curves represent the area on the top of the shape. the area between the middle and bottom represent the area on the bottom of the shape.
i have to find a way to calculate it.
i have no idea.
i tried integrating the curves to find the areas for the top and base and averaging them and multiplying by the height. (basically trapeoid rule sort of)
but this is only an approximation!
CAN ANYONE GIVE ME AN ACCURATE WAY OR A BETTER APPROXIMATION!
help!
need help urgently
I think that the answer is "yes, there is a way," but I cannot understand your exact situation. Please post a figure so that we can work the correct problem.
Not sure what you mean by revolving an area around a curve. One normally revolves entities around axes. Do you mean it is translated along a curve?
What is the relationship between the parabolas? E.g. do they all intersect, in symmetric fashion, at the same two points, or are they identical and 'parallel'?
My guess is that the parabolas are something like y = a x2+ci, i = 1, 2 , 3, and intersections of the solid with planes orthogonal to the x-axis produce a constant shape.
Oh, and I don't understand
Do you mean it's connected to two adjacent vertices, forming a pentagon?
@ haruspex: That is why I asked for a picture.
Hey guys, this thread was created in 2009 so brandy is most likely not going to reply to anything here.
How true, brandy will have surely evaporated.
Just as a matter of interest: any guesses as to why did thread suddenly re-appeared?
My best guess is that maybe OldEngr was browsing "Unanswered Threads" and this one somehow snuck its way in.
