Can SU(3) be visualized with three belts?
  • Context: Graduate
  • Thread starter Thread starter Franca.Jones
    Su(3)
The discussion centers around the visualization of the special unitary group SU(3) and its potential representation using three belts, similar to how SU(2) is visualized with a single belt. Participants explore the implications of this visualization in relation to the structure of SU(3) and its subgroups, as well as its connections to theoretical physics concepts such as gauge theories and unification.
  • Franca introduces the idea of visualizing SU(3) with three belts, drawing a parallel to the Dirac belt used for SU(2).
  • François mentions a manuscript by Schiller that employs a triple belt trick to model the strong interaction, suggesting it may provide insights into Franca's inquiry.
  • Participants discuss the Dirac belt and its use in illustrating SU(2) and spinor symmetry, with references to Penrose's work.
  • Franca expresses interest in using the three belts to understand nuclei and notes the ambitious nature of Schiller's manuscript, which attempts to derive various quantum field theories from topological arguments.
  • Franca shares that the three belt idea is not widely known, and searches yield no relevant results, indicating a lack of established literature on the topic.
  • Franca describes the eight generators of SU(3) as rotations by 180 degrees, with some participants attempting to deduce their products, though uncertainty remains about the completeness of these deductions.
  • Heinz provides an assessment of claims related to Reidemeister moves and their potential connection to gauge groups, emphasizing the speculative nature of these connections and the need for experimental validation.
Participants express a range of views on the visualization of SU(3) and the validity of the claims made in Schiller's manuscript. There is no consensus on the effectiveness of the three belt visualization or the implications of the claims regarding Reidemeister moves and gauge theories.
Participants acknowledge that the connections between the visualization methods and physical theories are not well-established and depend on various assumptions. The discussion highlights the speculative nature of the proposed relationships and the need for further exploration.
Franca.Jones
Dear PFers,
I am looking for a way to visualize SU(3). I have heard from a friend
(who heard it as a rumor) that like SU(2) can be
visualized with a (Dirac) belt, also SU(3) can be visualized, but
with three belts, because SU(3) has three independent copies of
SU(2) as subgroups.
I found no material on this on the internet.
Is there anybody who can help me with more details? Thank you!
Franca
SU(2) as subgroups.
Hi Franca,
the only place I have seen something similar is the last manuscript
on http://www.motionmountain.net/research
where Schiller uses the triple belt trick to model the strong
interaction. Does this help you?
François
what's the Dirac belt?
Penrose used the single belt in a book to illustrate SU2 and spinor symmetry on around p200 of his Road to Reality from memory. Maybe your friend saw those pictures?
But not come across a three belt illustration of SU3.
The 1 belt trick is also illustrated on p21 of this paper...
http://website.lineone.net/~cobble6/Clifford Report.pdf
interaction.
François
Thank you, that preprint is very interesting! I wanted the three
belts to understand nuclei, but that manuscript does something
much more ambitious: it tries to derive QED, QCD and QAD from
topologocal arguments. Incredible!
Franca
P.S. I very much like this (single) belt trick applet:
http://gregegan.customer.netspace.net.au/APPLETS/21/21.html
thanks - now I remember
In the meantime, I asked a bit around. The three belt idea is not
well-known yet. Searching for "three belts" and "SU(3)" gives
no hits anywhere. the manuscript above is a bit terse on
the topic, probably because the main topic is unification.
The main idea is that SU(3) has three copies of SU(2)
that are linearly independent. Each SU(2) can be modeled
by one belt. So three copies need three belts.
Then the three belts are connected by joints.
The 8 generators of SU(3) are explained as rotations by 180
degrees; and their products are said to be concatenations.
But though I can deduce some of the products, I fail
for others.
Did anybody else try?
Franca
for others. Did anybody else try?
Franca
I have tried a few products, and it seems to work out. The rest of the
file is more intriguing: the guy is going for the holy grail
of physics... It is quite a change in approach to what is seen around.
Unification in 3 d , unusual SU(2) symmetry breaking proposal, no GUT, non Susy - that is not the usual stuff...
François
franoisbelfor said:
The rest of the
I asked about this on usenet. It seems to me that the approach has a chance.
I will post more on this approach to unification once I have made up my mind.
Franca
On sci.physics.research, Heinz posted this assessment:
Franca, tell me if I write too much or too little. Here is what I get
from that text. It has 2 claims.
One is mathematical. It claims that the first Reidemeister move (that
is a standard way to deform knots)
is a generator of U(1), the second move(s) gives the generators of SU
(2), and the third Reidemeister
moves gives the generators of SU(3). See the wikipedia entry
http://en.wikipedia.org/wiki/Reidemeister_move .
*IF* the connection is correct, then the answer to
your question is that the gauge groups can indeed be related/tied to 3
dimensions.
The opposite is true if the claim is wrong. But even if the claim is
correct,
this does not mean that the physical gauge groups (as opposed to the
mathematical groups)
really are due to 3 dimensions. Other explanations are possible:
string theory.
So the answer to your question is: "maybe."
The other claim is physical: Schiller claims that particles are
tangles, and that
Reidemeister moves model gauge interactions. That can only be tested
against experiment. Schiller says that tangles lead to the Dirac
equation, and
gives a published paper from 1980 as a proof, plus an unpublished text
by himself.
*IF* the reasoning is correct, test with experiment would not be
necessary: it is
known that the Dirac equation is very precise.
The opposite is true if the reasoning is wrong. The 1980 paper appears
to
have almost no citations. So the answer to this claim is "hmm".
Does this answer your question?
Heinz
I will read the 1980 paper and more on Reidemeister things and come back soon.
Franca
  • · Replies 26 ·
  • · Replies 27 ·
9K
  • · Replies 61 ·
11K
