Schwarz's lemma, complex analysis proof
The discussion centers on applying Schwarz's Lemma to prove that for a holomorphic function f defined on the unit disk B1, with Re f(z) ≥ 0 and f(0) = 1, the inequality |f(z)| ≤ [(1 + |z|)/(1 - |z|)] holds. Participants emphasize the necessity of constructing a mapping function g from the half-plane H to the unit disk, specifically ensuring g(1) = 0. The composition h = g(f) is then analyzed using Schwarz's Lemma to derive the required result, with additional algebraic manipulation to finalize the proof.
  • Understanding of complex analysis concepts, specifically Schwarz's Lemma.
  • Knowledge of holomorphic functions and their properties.
  • Familiarity with mappings between the half-plane and the unit disk.
  • Basic algebraic manipulation skills in the context of complex functions.
  • Study the applications of Schwarz's Lemma in complex analysis proofs.
  • Explore the properties of holomorphic functions in the unit disk.
  • Learn about conformal mappings from the half-plane to the unit disk.
  • Practice algebraic techniques for manipulating complex inequalities.
Students of complex analysis, mathematicians focusing on holomorphic functions, and anyone interested in advanced proof techniques involving Schwarz's Lemma.
QuantumLuck
Let B1 = {z element C : abs(z) < 1}, f be a holomorphic function on B1 with Re f(z) > greater than or equal to 0 and f(0) =1. then show that:
abs(f(z)) less than or equal to [(1+abs(z))/(1-abs(z))]
Schwarz's Lemma: Suppose that f is analytic in the unit disc, that abs(f) less than or equal to 1 and that f(0) = 0. Then
i. abs(f(z)) less than or equal to abs(z)
ii. abs(f'(0)) less or equal to 1
So I know that the solution to this problem involves utilizing Schwarz's lemma (a hint from my professor), however considering the different value of the point at z = 0 is throwing me for a loop. I am not quite sure how to continue from where I am.
You have f from B1 to H, where H is the half plane {z : Re(z)>0}.
Now create a function g which maps H into the unit disc, such that g(1)=0.
Let h = composition of g and f. Apply Schwarz to h. After that, a little extra algebra is needed to get the desired conclusion.
  • · Replies 17 ·
