Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Number Theory
Reply
image recursively defined numbers, need to show they are non-decreasing Share It Thread Tools Search this Thread image
Old Apr29-09, 12:32 PM       Last edited by math_question; Apr29-09 at 03:00 PM..            #1
math_question
math_question is Offline:
Hello, I have a question involving a sequence of numbers LaTeX Code:  \\{a_n\\}  defined recursively. They are defined as the positive solutions of the following set of equations.
LaTeX Code: 1 = \\frac{1}{a_1} = \\frac{1}{(a_2+a_1)} + \\frac{1}{{a_2}} =<BR>\\frac{1}{(a_3 + a_2 +a_1)} + \\frac{1}{(a_3 + a_2)}<BR>+ \\frac{1}{{a_3}} = \\cdots = \\frac{1}{(a_n + a_{n-1}+ \\cdots +a_1)} + \\frac{1}{(a_n + a_{n-1}+<BR>\\cdots +a_2)} + \\cdots + \\frac{1}{{a_n}} = \\cdots
The first few can be solved analytically LaTeX Code:  a_1 = 1, a_2 \\approx 1.62, \\cdots  . The rest can be found numerically.
However, instead of their values, what I need is to show that these numbers have to be non-decreasing, i.e. LaTeX Code:  a_{n+1} \\geq a_{n}  for all n.
Any ideas welcome.
Thank you.
Notes:
An observation that might be helpful is that, the numerical solutions show a_n's grow with natural logarithm. (LaTeX Code: \\ln{(2n+2)} seems to fit the numerical solution perfectly. ) Also, LaTeX Code: a_n \\geq H_n, \\text{\\, where \\,}<BR>H_n = \\sum_{k=1}^{n}\\frac{1}{k} \\text{\\, is the $n^{\\text{th}}$<BR>harmonic number.}
The numerical solution suggests LaTeX Code:  a_{n+1} - a_n  goes to zero as n goes to infinity. So this might suggest induction is the way to go for the proof. Assume non-decreasing up to a_n, show that LaTeX Code:  a_{n+1} \\geq a_{n}  .
image image
Reply
Tags
non-decreasing, recursive
Thread Tools
Similar Threads for: recursively defined numbers, need to show they are non-decreasing
Thread Thread Starter Forum Replies Last Post
Decreasing numbers equation chewtoy929 Linear & Abstract Algebra 4 Mar26-09 05:25 PM
How many n-digit numbers have their digits in non-decreasing order? 666999 Set Theory, Logic, Probability, Statistics 0 Sep22-08 04:31 PM
How do I show that the real numbers are not compact? fred123 Calculus & Beyond 10 Nov19-06 02:33 PM
Numbers with Non-Decreasing Digits e(ho0n3 General Math 32 Oct15-04 07:55 PM
can I use an analogus function to show that the sequence is increasing or decreasing? thiago_j Introductory Physics 5 Sep28-04 01:34 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
