Max Contraction of Two Moving Bodies with Spring Attachment
The discussion revolves around the dynamics of two bodies moving towards each other on a frictionless surface, connected by a spring. The participants are exploring the concept of maximum contraction of the spring and the energy transformations involved, particularly in the context of the center of mass (C.O.M) frame.
  • Participants discuss the relationship between kinetic energy and potential energy in the C.O.M frame, questioning why all kinetic energy is converted to potential energy at maximum spring compression. There are inquiries about the definition of relative velocity and its implications in different reference frames.
The discussion is ongoing, with participants expressing confusion about the energy conservation principles in the C.O.M frame and how they relate to absolute velocities. Some have offered interpretations of the mechanics involved, while others are still seeking clarity on the concepts presented.
Participants are grappling with the implications of using different reference frames, particularly the C.O.M frame versus an inertial frame at rest. There is a recognition of the complexity introduced by the different velocities of the masses and the need for further exploration of these dynamics.
Dweirdo
2 bodies move towars each other M1 WITH Velocity V1 and M2 with velocity V2 ,on a frictionless surface with a spring between them(attached to M1),what will be the maximum contraction(I mean You know, shrink or W\E)?
reduced mass =[tex]\bar{M}[/tex]=M1M2/(M1+M2)
now the solution says that in Center of Mass frame , all the kinetic energy is transferred to potential energy:
0.5[tex]\bar{M}[/tex]*V(1,2)=0.5K*A(max)^2
now why is that? I can't see it! in C.O.M after the spring has shrunk A(max ) the bodies are @ rest in C.O.M frame? how is that?
Thanks in advanced.
Thanks in advanced.
Not sure what you mean with the reduced mass thing. The masses have different velocities initially -- that doesn't seem to show up in your equation... what is V(1,2) ?
V(1,2)=v1+v2 relative velocity .
forgot to square it, should be
0.5*[tex]\bar{M}[/tex]V(1,2)^2=0.5K*A(max)^2
this is the solution from the book, what I don't understand is why in the C.O.M frame all Kinetic energy is converted when A is max.
When the bounce happens (relative and absolute velocities go to zero), that's the instant of the max compression on the spring -- at least that's the way I interpret the question.
So how is that differ from a frame of reference that is @ rest?
this question is to show how elegenat is the solution from the center of mass frame ,
if when the spring shrinks to its maximum the absolute velocities go to zero than in frame @ rest we will get different answers.
still confused :S
Maybe if the masses have a velocity component that is orthogonal to their approach component... Those velocities aren't seen in the COM frame? Dunno beyond that. Sorry.
Yap this is a tough one,
It doesn't make sense :S in c.O.m which moves with speed of (m1v1+m2v2)/(m1+m2)
and let's say it's directed right and M1 is going left initially, after the spring was compressed it has to go in the right direction(in the C.O.M) so that some how relative velocity will be 0.
arghh stupid question, thank You that You've tried to help!
any one?
thanks.
Using the ground as a frame of reference is hardly rocket science:
When the relative velocity is 0, the masses have the same velocity V
(actually the velocity of the C of M).
M1V1 - M2V2 = (M1+M2)V
Final KE = 1/2(M1+M2)V^2
You can check that the initial KE referred to the ground exceeds
that in the C of M frame by precisely this amount.
This rox!
It actually means that V(final) =V of center of mass, thus In C.O.M both bodies are @ rest!
Awesome thanks!
