Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Number Theory
Reply
image constructible root from cubic polynomial Share It Thread Tools Search this Thread image
Old Apr29-09, 07:59 PM                  #1
hanelliot
hanelliot is Offline:
Does x^3 - 3x + 3sqrt(3) = have a constructible root?
my solution:
suppose a is a constructible root of the equation above.
we square both sides to get x^6 - 6x^4 + 9x^2 = 27.
since a is constructible, a^2 is constructible as well and we can turn this equation into cubic poly with rational coefficients, and it becomes y^3 - 6y^2 + 9y - 27 = 0.
If this cubic poly has a constructible root, it must have a rational root in form of m/n.
(m/n)^3 - 6(m/n)^2 + 9(m/n) = 27.
How do I proceed from here? Detailed steps would be appreciated..
Old May1-09, 01:53 AM                  #2
robert Ihnot
robert Ihnot is Offline:
Recognitions:
PF Contributor PF Contributor
Re: constructible root from cubic polynomial
The form will wind up as m^3-6m^2n+9mn^2-27 n^3 =0. This is supposed to be a solution. (We assume that m and n are relatively prime, that is, contain no common factors.) So look at m, there is only 1 term in which it is not present.
So take it from there!
Old May1-09, 07:20 AM                  #3
HallsofIvy
PF Mentor
HallsofIvy is Offline:
If it has a rational root, m/n, then m must divide the constant term and n must divide the leading coefficient. Here the constant term is -27 so m must be 1, -1, 3, -3, 9, -9, 27, or -27. The leading coefficient is 1 so the n must be either 1 or -1 which means the only possible rational roots are 1, -1, 3, -3, 9, -9, 27, or -27. Do any of those satisfy the equation?
Old May2-09, 06:12 PM                  #4
Count Iblis
Count Iblis is Offline:
Recognitions:
Homework Helper Homework Helper
You can apply the Rational Roots Theorem to
as HallsofIvy explained, but it is possible to reduce the number of root candidates by substitution.
Define
P(y) = y^3 - 6y^2 + 9y - 27
P(1) = -23, so y = 1 is not a root. Then, instead of trying out the other candidates, you can look at the polynomial:
Q(t) = P(1+t)
The coefficient of t^3 in Q(t) is 1 and the constant term in Q(t) is
Q(0) = P(1) = -23
This means that any rational root of Q(t) must be a divisor of 23, so the possible roots are:
t = 1, -1, 23, -23
The possible rational roots of P(y) are then the values of 1+t which are:
y = 2, 0, 24, -21
But any rational root must also be in the list give by HallsofIvy. Since none of the values for y listed above are on that list, there are no rational roots.
image image
Reply
Thread Tools
Similar Threads for: constructible root from cubic polynomial
Thread Thread Starter Forum Replies Last Post
Proove that the cubic root of 2 + the square root of 2 is irrational ehj Calculus & Beyond 4 Nov10-08 03:19 PM
Cubic Root Wazovolan Programming & Comp Sci 3 Oct30-07 12:57 PM
Roots of a cubic polynomial rock.freak667 Precalculus Mathematics 4 Aug29-07 04:35 PM
Creating a non-cubic polynomial rainyrabbit Precalculus Mathematics 4 Jun26-06 05:36 PM
need proof that a cubic equation has at least one real root lmamaths General Math 2 Apr22-05 08:41 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
