Formation of the geomagnetic field
  • Thread starter Thread starter cats0410
    Field Formation
The discussion centers on the formation of the Earth's geomagnetic field, exploring various hypotheses, particularly the dynamo theory, and the complexities surrounding the mechanisms that generate and influence the magnetic field. Participants delve into the relationship between the Earth's core dynamics, electrical currents, and the observed variations in the magnetic field, including pole reversals and anomalies.
  • Some participants suggest that the Earth's magnetic field is generated by the movement of liquid metal in the core due to convection and rotation, which produces electrical currents.
  • Others argue that the dynamo hypothesis, while widely accepted, does not fully explain phenomena such as magnetic pole reversals and the behavior of the geomagnetic field over time.
  • A participant mentions that the South Atlantic magnetic anomaly is drifting west at 0.3 degrees per year, raising questions about how core processes can create organized reversal patterns on the surface.
  • Some contributions highlight that the geomagnetic field exhibits variations in intensity with cycles of 30,000 and 100,000 years, suggesting a potential link to orbital changes.
  • There are references to studies indicating that geomagnetic excursions, where the field's intensity drops significantly, may occur more frequently than previously thought.
  • Participants note that the self dynamo mechanism is increasingly challenged by recent observations, particularly regarding the South Atlantic anomaly and its drift rate.
  • One participant points out that the drift rate of the South Atlantic Anomaly aligns closely with the estimated rotation differential between the Earth's core and its surface.
Participants express a range of views on the mechanisms behind the geomagnetic field, with no consensus reached on the validity of the dynamo theory or the implications of recent observations. Multiple competing hypotheses are presented, and the discussion remains unresolved.
Some claims rely on specific assumptions regarding the behavior of the Earth's core and the nature of magnetic field variations, which are not universally accepted or tested. The discussion includes references to complex models and observational data that may not be fully reconciled.
cats0410
Hi All,
I´m quite new to physics (from a biology background) and am hoping someone can give me a quick explanation of what causes the Earth to have a magnetic field. I have read about the dynamo theory but am finding it difficult to visualise or is it as simple as moving currents make an electric field?
Thanks for your help
We do not know what causes the Earth to have an magnetic field. We only have hypotheses about that, which are supported by observations.
I'll try to elaborate more later today - priorities.
The Earth's core is made of a combination of liquid and solid metal. The liquid portion moves due to convection and the Earth's rotation. This movement produces electrical currents which in turn produce the magnetic field.
We know that the Earth's magnet field is not produced like a conventional magnet since conventional magnets loose their strength at the high temperatures found inside the earth. Also, the movement of the liquid metal varies over time, as does the strength of the Earth's magnetic field.
There are also electrical currents produced in the upper reaches of the atmosphere that induce a level of magnetism. These fields are also influenced by storms on the sun.
A magnetic field is directly related with moving electrical charges according to the Lorentz law.
Hence the dynamo hypothesis due to Earth rotation has reigned for a long time, rotating Earth driving magnetism, but that could not explain the numerous magnetic pole reversals and Earth magnetic excursions.
http://www.psc.edu/science/glatzmaier.html succeeded in modelling an Earth core model in which the Earth magnetic field is assumed to be the resultant of several counter rotating convection cells, which basically tend to cancel each other out. Turbulent variation in those convection cells would explain why the Earth magnetic field can suddenly collapse and or reverse in polarity, just due to changes in the balance of the counter rotating convection cells in the outer core.
However it still remains an hypothesis, since there is no way to test it from a prediction
The self dynamo mechanism is hypothesized to create both the geomagnetic field and the solar field. In both cases recent observations are becoming increasingly difficult for the self dynamo theory to explain.
In the case of the Earth recent observations indicate the South Atlantic magnetic anomaly is drifting west at 0.3 degree/year. The South Atlantic magnetic anomaly is a region of the planet's core that is attempting to change magnetic polarity. The question is how can core processes that are 10^5 times slower create an organized reversal pattern on the surface that is moving at 0.3 degree/year.
Another observation that is peculiar is that the geomagnetic field appears to varying intensity with a cyclic of 30 kyr and 100 kry. (i.e. It is not changing random.) As 100 kyr and 30kyr cycles are similar to orbital cycles, some researchers have searched for a mechanism whereby orbital changes somehow affects the planet's core.
http://arxiv.org/abs/0902.2873
Temporal Variations of Strength and Location of the South Atlantic Anomaly as Measured by RXTE
The evolution of the particle background at an altitude of approx. 540km during the time interval between 1996 and 2007 is studied using the particle monitor of the High Energy X-ray Timing Experiment on board NASA's Rossi X-ray Timing Explorer. A special emphasis of this study is the location and strength of the South Atlantic Anomaly (SAA). The size and strength of the SAA are anti-correlated with the 10.7 cm radio ux of the Sun, which leads the SAA strength by approx. 1 year re-ecting variations in solar heating of the upper atmosphere. The location of the SAA is also found to drift westwards with an average drift rate of about 0.3 degrees/yr following the drift of the geomagnetic field configuration. Superimposed to this drift rate are irregularities, where the SAA suddenly moves eastwards and where furthermore the speed of the drift changes. The most prominent of these irregularities is found in the second quarter of 2003 and another event took place in 1999. We suggest that these events are previously unrecognized manifestations of the geomagnetic jerks of the Earth's magnetic field.
From archeomagnetic data Pinto et al. (1992) have shown that the SAMA (South Atlantic Magnetic Anomaly) has been slowly drifting westwards for at least 1400 years. This long-term drifting was recently confirmed by Mandea et al. (2007), using data calculated via the GUFM model (Jackson et al., 2000) and the CHAOS model (model from the satellites CHAMP, Orsted and SAC-C, Olsen et al., 2006).
Is the geodynamo process intrinsically unstable?
http://eprints.whiterose.ac.uk/416/
Recent palaeomagnetic studies suggest that excursions of the geomagnetic field, during which the intensity drops suddenly by a factor of 5 to 10 and the local direction changes dramatically, are more common than previously expected. The `normal' state of the geomagnetic field, dominated by an axial dipole, seems to be interrupted every 30kyr to 100 kyr; it may not therefore be as stable as we thought.
Recent studies suggest that the Earth's magnetic field has fallen dramatically in magnitude and changed direction repeatedly since the last reversal 700 kyr ago (Langereis et al. 1997; Lund et al. 1998). These important results paint a rather different picture of the long-term behaviour of the field from the conventional one of a steady dipole reversing at random intervals: instead, the field appears to spend up to 20 per cent of its time in a weak, non-dipole state (Lund et al. 1998).
This picture summary provides some historical information concerning geomagnetic theory.
http://www.scostep.ucar.edu/comics/books/ste_geomag_e.pdf
Actually, the drift rate of the South Atlantic Anomaly is very close to the rotation differential between the Earth's core and its surface, estimated to be between 0.3 and 0.5 degrees per year.
http://en.wikipedia.org/wiki/Earth's_rotation
The Earth of course rotates counterclockwise. The earth’s core also rotates counterclockwise with a rotation speed that is roughly 0.4 degrees faster than the crust.
If the South Atlantic Anomaly was created by core based activities it seems the South Atlantic Anomaly would be moving to the east as the core moves ahead of the crust.
The South Atlantic Anomaly is however moving to the west and has been moving to the west for the last 1400 years.
Magnetic field anomalies also move to the the west.
Something is puzzling here.
http://www.livescience.com/environment/050825_earthcore.html
Earth's Core Rotates Faster than Surface, Study Confirms,
By analyzing the minute changes in travel times and wave shapes for each doublet, the researchers concluded that the Earth's inner core is rotating faster than its surface by about 0.3-0.5 degrees per year.
You're assuming one current loop yielding an approximate dipole, which is not the case (though close enough for everyday use). There's a complex mix of them, so it's not too surprising that the movement you describe isn't as you think it should be. What do you mean by "magnetic field anomalies also move to the west"? To what anomalies are you referring? (I'm a crustal geophysicist so the discussion of whole-earth processes is slightly out of my area of expertise)
  • · Replies 0 ·
9K
  • · Replies 20 ·
