Complex Power Series: Does Absolute Convergence Imply Convergence?
In complex analysis, absolute convergence of a power series implies convergence, but the reverse is not true. A series can converge conditionally without being absolutely convergent, as demonstrated by the series ∑_{n=0}^∞ (-1)^n/m, which converges but does not converge absolutely. Power series have a defined radius of convergence, where they converge absolutely within the radius and diverge outside it. On the boundary of this radius, the series may either converge absolutely, converge conditionally, or diverge.
  • Understanding of complex analysis concepts
  • Familiarity with power series and their properties
  • Knowledge of convergence tests in series
  • Basic mathematical notation and summation
  • Study the concept of "radius of convergence" in power series
  • Learn about different convergence tests, such as the Ratio Test and Root Test
  • Explore conditional versus absolute convergence in series
  • Investigate examples of series that converge conditionally
Students and professionals in mathematics, particularly those studying complex analysis, as well as educators teaching series convergence concepts.
Niles
Hi all.
In my book on complex analysis, they discuss complex power series. They use a variety of "tests" to determine absolute convergence, but they never say if this also implies convergence.
Does it?
Niles.
If a series convergerges "absolutely" then, yes, it must converge. The other way is not true: if a seriies converges, it does not necessariily converge absolutely. For example, the series
[tex]\sum_{n=0}^\infty \frac{(-1)^n}{m}[/tex]
Most of the time, when you are dealing with complex series, you are dealing with power series. In that case, there always exist a "radius of convergence". Inside that radius, the power series muist converge absolutely, outside it, diverge. But on the radius of convergence, the series may converge absolutely, converge but not absolutely (converge "conditionallly"), or diverge.
Thank you very much.
  • · Replies 22 ·
