How can I call a dll from VB.NET for a particle simulation?
  • Thread starter Thread starter Pauly Man
7 replies · 76K views
Pauly Man
I've created a dll in c++ that runs a 4th order Runge-Kutta on user supplied data. I want to use it in a particle simulation, which I already have in vb.net. The trouble is I have no idea how to call the dll from within vb, any ideas?
ps- I've tried using the info provided on msdn, but I'm not sure if I'm doing it right. Basically the dll file is called "RungeKuttaDLL.dll", the lib file is called "RungeKuttaDLL.lib" and the function for export within the dll is called "RungeKutta". msdn gave me this info:
Private Declare Function RungeKutta Lib "c:\Documents and Settings\PB Customer\My Documents\Visual Studio Projects\VB\NumericalMethods\RungeDLL\RungeKuttaDLL.dll"(ByVal X0 As Double, ByVal Y0 As Double, ByVal H As Double, ByVal N As Integer) As Double
It doesn't work though.
Put your DLL in your bin folder. Then in your code at the top type "Imports ..." (... = whatever namespace is in your dll). Now you have access to your classes in the dll.
I still can't get it to work. I looked at some examples on the net, and they all seem to work, but only have one function in the dll, or are API calls. I get an error message when I try and compile, and it tells me it can't find an entry point called RungeKutta. I've looked all over the ent, and there is nothing of use that I can find. I may just give up and work out how to program it all in c++, vb seems way too complicated and too much trouble, which is an oxymoron when you think about it.
Module RungeDLL
Declare Function RungeKutta Lib "c:\Documents and Settings\PB Customer\My Documents\Visual Studio Projects\VB\NumericalMethods\RungeDLL\bin\RungeKuttaDLL.dll" Alias "RungeKutta" (ByVal X0 As Double, ByVal Y0 As Double, ByVal H As Double, ByVal N As Integer) As Double
End Module
Imports RungeDLL
Public Class Form1
Inherits System.Windows.Forms.Form
#Region " Windows Form Designer generated code "
Public Sub New()
MyBase.New()
'This call is required by the Windows Form Designer.
InitializeComponent()
'Add any initialization after the InitializeComponent() call
End Sub
'Form overrides dispose to clean up the component list.
Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)
If disposing Then
If Not (components Is Nothing) Then
components.Dispose()
End If
End If
MyBase.Dispose(disposing)
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
<System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()
'Form1
Me.AutoScaleBaseSize = New System.Drawing.Size(5, 13)
Me.ClientSize = New System.Drawing.Size(292, 266)
Me.Name = "Form1"
Me.Text = "Form1"
End Sub
#End Region
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
RungeKutta(0.0, 0.0, 0.2, 5)
End Sub
End Class
I have never really thought about using c# before, maybe I should.
oh it's a regular C++ DLL, you know there is also a C++.net :smile:
anyway here you go
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/cpref/html/frlrfSystemRuntimeInteropServicesDllImportAttributeClassTopic.asp
I've worked it out. I don't fully understand why it works now, but it does, so Hooray!
