What Happens to Charge and Energy When Connecting Capacitors in Parallel?
  • Thread starter Thread starter desmal
    Capacitors Energy
When connecting capacitors in parallel, charge conservation and energy conservation principles apply. If an uncharged capacitor is connected to a fully charged capacitor of equal capacitance, the final voltage (Vf) across both capacitors is calculated as Vf = Vi/sqrt(2). The total charge after connection (Qt) becomes C*Vi*sqrt(2), which does not equal the initial charge (C*Vi) of the charged capacitor. This discrepancy arises because energy is lost as heat during the charge redistribution process, while charge remains conserved.
  • Understanding of capacitor fundamentals
  • Knowledge of electrical energy conservation principles
  • Familiarity with parallel circuit configurations
  • Basic algebra for calculating voltage and charge
  • Study the principles of energy dissipation in electrical circuits
  • Learn about the implications of connecting capacitors in series vs. parallel
  • Explore detailed examples of charge distribution in capacitor networks
  • Investigate the effects of resistance in capacitor discharge scenarios
Electrical engineering students, circuit designers, and anyone interested in understanding capacitor behavior in parallel configurations.
desmal
I am not sure if I have full understanding of capacitors energy, because I found a contradiction in solving one problem. The problem is: -
If an uncharged capacitor connected to another fully charged capacitor in parallel, what will be the new charge distribution on both capacitors? “Assuming equal capacitance”
I believe we have two rules of respect:-
1- Conservation of charge
2- Conservation of energy
If we assume that C = capacitance, and Vi = initial voltage and Qi=the initial charge on the charged capacitance.
Let the energy before connecting the two capacitance equal to the energy after linking them together:-
0.5*C*Vi^2 = 0.5*(2C)*Vf^2
then: - Vf=Vi/sqrt(2)
Know consider the total charge after linking both capacitors:-
Qt = Ct * Vf= (2C)*Vi/sqrt(2)=C*Vi*sqrt(2)
Which is obviously not equal to C*Vi “the initial charge”.
I am confused which one of these two fundamental concepts I have to base my calculation in, and why it doesn’t work with the other concept.
Charge is conserved as is energy, however,when the capacitors are joined together charge flows through the connecting wires and electrical energy is converted to heat energy this being dissipated to the surroundings.The result is that the energy stored in the field of the capacitor combination is less than the energy stored in the single capacitor that was originally charged,the amount of charge,however, is the same.
  • · Replies 17 ·
