Solution check for pH of Strong Acid and Strong Base
  • Thread starter Thread starter pavadrin
    Acid Base Ph
The discussion focuses on calculating the pH after adding 24 mL of 1.00 M NaOH to 25.0 mL of 1.00 M HCl. The combined volume of the solution is 49 mL, resulting in an unreacted hydrogen ion concentration of 0.02 mol/L. The final pH is calculated to be 1.69, confirming the accuracy of the solution provided by the user pavadrin.
  • Understanding of acid-base neutralization reactions
  • Familiarity with the pH calculation formula, pH = -log [H+]
  • Knowledge of molarity and volume calculations
  • Basic concepts of strong acids and bases
  • Review the principles of acid-base titration
  • Study the concept of neutralization and its impact on pH
  • Learn about the ion product of water, Kw = [H+][OH-]
  • Explore advanced pH calculations in mixed solutions
Chemistry students, educators, and anyone involved in laboratory work related to acid-base reactions and pH calculations.
pavadrin
Calculate the pH after 24 mL of 1.00 M NaOH is added from the burette to a beaker containing 25.0 mL of 1.00 M HCl
pH = -log [H+]
1*10^-14 = [H+][OH-]
combined volume = 49mL
n.unreacted(H+) = 0.025-0.024 = 0.001 mol
[H+] = n/V = 0.001/0.049 = 0.02 mol L-1
pH = -log[H+] = 1.69 (2 d.p)
is that correct?
many thanks,
pavadrin
Yes.
okay thank you for the reply
