| Thread Closed |
Temperature change after flow through an oriface |
Share Thread | Thread Tools |
| May3-09, 08:36 PM | #1 |
I'm interested in modelling the effect of a chamber of ideal gas at a high pressure passing through subsequent chambers of lower pressure gas - each subsequent chamber joined to the previous via a thin plate oriface.
I'm looking at at an iterative solution (i don't do integrals) and i am happy that i can calculate the instantaneous flow of gas through an orifice between chambers - whether chocked or not. I can not find how to calculate the temperature change of the gas in each of the chambers either side of the orifice as a result of the flow (assuming no 'velocity' of gas remains in any of the chambers). There is no work being done in the system and I know during a free adiabatic expansion the temperature is constant but this scenario is different - I assume temperature/internal energy will drop in the high pressure side and increase in the low pressure side as the gas passes through the orifice - but by how much - can someone point me to a formula or another way of looking at the problem? |
| May6-09, 04:27 AM | #2 |
Ok - lets put some real figures on this to get the ball rolling....
Assume the gas concerned is air - 29 mol/g, k=1.4 Chamber A has 5g of air (0.1724 mols) in 1 litre at 1000 Kelvin. P=nRT/V pressure = 1.433Mpa density = 5g/l (5kg/m3) Chamber B has 2.4g of air (0.0827 mols) in 2 litres at 300 Kelvin pressure = 0.103Mpa density = 1.2 g/l The chambers are connected by a 10mm diameter orifice with a discharge Coefficient (C) of 0.76 If the orifice was opened for approx 4.7 milliseconds then closed then I calculate around 0.5 grams of gas would rush under choked conditions to chamber B. But what would the pressure/temperature be in both of the chambers assuming no loss of energy outside the system? any help, informed guesses, discussion is welcome! |
| May9-09, 12:21 PM | #3 |
any one - am I asking something difficult/unknown?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Temperature change after flow through an oriface
| Kelvin Temperature - Celsius Temperature Change | General Physics | 12 | ||
| Chemistry: Finding a temperature change using a temperature/gram ratio | Biology, Chemistry & Other Homework | 3 | ||
| Water mixing temperature- different flow rates | Engineering, Comp Sci, & Technology Homework | 2 | ||
| How pressure and temperature affects volumetric flow? | Classical Physics | 6 | ||
| Temperature change, temperature derivative of material? | General Physics | 0 | ||
