Mass (both relativistic and rest) of a photon
The discussion revolves around the concepts of mass, both relativistic and rest, in relation to photons. Participants explore the implications of relativistic mass equations, the nature of energy in photons, and the compatibility of quantum mechanics with classical mechanics regarding mass.
  • Some participants express confusion about the relationship between the energy of a photon, given by E = hf, and the concept of mass, particularly in light of the equation E^2 = p^2c^4 + m0^2c^4.
  • Others argue that if the rest mass m0 is zero, then the equation should yield zero, leading to questions about how a photon can possess energy without mass.
  • Some participants highlight that the relativistic mass formula becomes undefined when both rest mass and velocity are zero, suggesting a need for clarification on the concept of mass for massless particles.
  • There is a discussion about the validity of using m0 = E/c^2 for moving objects, with some asserting that this equation only applies to objects at rest.
  • One participant mentions that physicists often prefer to avoid the term "relativistic mass" and focus on energy instead, suggesting that relativistic mass can be expressed as E/c^2.
  • Another point raised is whether the mass of a photon can be considered finite and real when it is in motion, with some suggesting it is always zero while others propose it could be defined in terms of energy.
  • Some participants note that the relativistic mass of a photon could be proportional to its frequency, leading to further questions about the implications of this relationship.
Participants do not reach a consensus on the nature of mass for photons, with multiple competing views on whether photons can be said to have mass and how to reconcile their energy with classical definitions of mass.
Limitations include unresolved definitions of mass in the context of relativistic physics, the applicability of certain equations to massless particles, and the implications of quantum mechanics on classical concepts of mass.
chiro
I have read over the definition of the derivation of the energy relationship with momentum and rest mass and I am a little confused.
By looking at the definition of relativistic mass we have the definition
m = m0 / SQR(1 - v^2/c^2) where m0 is the rest mass.
Now a photon always travels at speed c (part of the relativity axioms) so the speed must be c and therefore the rest mass must be zero.
Now enter quantum mechanics. It turns out that the energy of the photon comes in "lumps" and the energy component of a photon is given by E = hf.
Now I'm ok with these two.
Now I also understand that mass != matter and that you can have something with mass and no matter that's fine.
What I don't get is how you can suddenly use the equation E^2 = p^2c^4 + m0^2c^4 and get a non-zero rest mass or even non-zero relativistic mass and as such even a non-zero energy given the mass of the photon in any state should be zero from the relativistic formula. It seems that the E=hf expression is completely incompatible with mass in the first place. So as you can see I'm a little confused as to how a photon of light can have any energy at all under standard mechanics (although i understand it when dealing with quantum mechanics).
For example if v = c then m0 must equal 0. Now any relativistic mass should by the definition of mass equal zero since both a) the rest mass is zero and b) the photon always travels at c which results in a).
I understand the definitions of momentum and how you use differential and integral calculus to go from momentum to force to energy etc.
Sorry for repeating this but it seems like there is an inconsistency in the whole system to me but I'm probably missing something so I'd welcome anyone to tell me what I'm missing.
Many thanks to any responses.
can you demonstrate how you conclude that E^2 = p^2c^4 + m0^2c^4 will give you a non-zero rest mass? If m_0 = 0, then it is = 0... since the photon is moving at v=c, one must have p = E/c, and that will give you m_0 = 0.
If m0 = 0 and v = c, the relativistic mass formula gives an undefined value of 0/0. It does not simply equal 0.
Well doesn't it have to be zero for the calculation to make sense otherwise you will get an infinite mass?
Actually I thought that you must have a non-zero rest mass to begin with. Sorry for the confusion.
What I'm confused about is where a photon can have any mass at all in any situation. I acknowledge that the photon has to absolutely have a rest mass of zero otherwise it wouldn't make sense. (Maybe I should edit my original post).
But what I don't understand is how you can get non-zero mass through m0 = E/c^2. Thats the part that gets me when we've already said that m0 = 0.
If rest mass is zero and nonrelativistic mass is zero then I'm happy with that but otherwise I don't understand. Sorry for the confusion earlier.
Doesn't what have to be zero?
That equation isn't valid; The correct version was given by malawi_glenn.
where was the equation m0 = E/c^2 introduced/derived??
Yeah, you can't have m0 = E/c^2 for a moving object, the equation E = m0*c^2 only works for an object at rest. For a moving object you have E = gamma*m0*c^2, where gamma = 1/sqrt(1 - v^2/c^2). If you want to think in terms of relativistic mass mR, this equation is E =mR*c^2. Also, note that with a little algebra it's possible to show that E = gamma*m0*c^2 is equivalent to E^2 = p^2*c^2 + m0^2*c^4, given the definition of the relativistic momentum p as p=gamma*m0*v.
In this case the relativistic mass equation gives
[tex]m_{rel} = \frac {m_0} {\sqrt{1 - v^2 / c^2}} = \frac {0}{0}[/tex]
which is undefined, not zero. This equation simply does not apply for a particle with zero rest mass.
I suppose another way you could look at it is that the equation above gives
[tex]0 \cdot m_{rel} = 0[/tex]
which is satisfied by any value for [itex]m_{rel}[/itex]!
Thanks for the feedback everyone I really appreciate it. My follow up question is if the photons mass is not zero when it is moving then what is it?
I know the photon always moves at speed c: this is a no brainer. I also realize that the photon has energy related to its frequency: again this is a no brainer.
What I have trouble with is the problem of finding the photons mass in a given situation. At rest its zero. But what about when its moving? Is it simply just undefined? or is there a way to show that its a finite and real quantity?
The photon's rest mass is zero at all times (and it's impossible for it not to be moving). Physicists these days usually prefer to avoid the concept of "relativistic mass" altogether and just talk about energy, since relativistic mass always obeys the equation E=mc^2 (assuming no potential energy, just rest energy and kinetic energy) and therefore relativistic mass is simply E/c^2. But if you wanted to define the relativistic mass for a photon, this equation combined with E=hf from quantum physics tells you it'd be hf/c^2.
Thanks for the response. So essentially the mass (relativistic) of a photon is always non-zero (since its always moving) and is proportional to the frequency of the light? This is my last question.
For relativistic mass, yes, those statements are right.
Cheers thanks everyone for your help
Is 'The Photon' the same as 'a photon'?
Who are you asking this to? Did someone use the capitalized phrase "The Photon"?
  • · Replies 19 ·
  • · Replies 55 ·
  • · Replies 131 ·
13K
  • · Replies 26 ·
  • · Replies 19 ·
  • · Replies 27 ·
