Answer: AC Voltage Source: Oscillation Around or Above Ground?
  • Thread starter Thread starter thoughtgaze
    Ac
The discussion revolves around the behavior of an alternating voltage source, specifically whether it oscillates around ground or above ground. The context includes considerations of function generators and their configurations.
  • Some participants suggest that the behavior of the oscillation depends on the specific characteristics of the source, such as amplitude, frequency, and DC offset.
  • One participant indicates that if the signal generator is grounded, the signal will oscillate above and below ground.
  • Another participant notes that typical sine and square waves produced by a signal generator are centered at ground, varying equally on either side.
  • It is mentioned that function generators can also produce logic pulses that vary from zero volts to a preset positive voltage, which may not oscillate around ground.
Participants express differing views on the conditions under which the oscillation occurs around or above ground, indicating that multiple competing perspectives remain in the discussion.
The discussion does not resolve the specific conditions under which oscillation occurs, highlighting the dependence on the configuration of the function generator and the definitions of ground and voltage levels.
thoughtgaze
So if my input is an alternating voltage source, some sort of function generator plugged into the wall... will it oscillate around ground or will it oscillate above ground? Hope this question makes sense.
Depends on the source. Most lab function generators let you specify Amplitude, Frequency, and DC Offset.
It's very likely that the signal generator will be grounded, if so then the signal will oscillate above and below the ground.
A signal generator will produce sine and square waves that are centered at ground and vary equally on either side of ground.
A function generator can do this too, but it can also generate logic pulses that vary from zero volts (ground) to some figure like plus 5 volts, which you can preset.
These pulses have the right voltage to drive logic circuitry for testing purposes.
  • · Replies 26 ·
  • · Replies 41 ·
