Why double integral could calculate area and volume
The discussion clarifies that double integrals can be used to calculate both area and volume, depending on the context of the integration. Specifically, when integrating over a two-dimensional region, double integrals yield area, while in three-dimensional contexts, they can represent volume. The key factor is the dimensionality of the solid being integrated; for example, an irregular cylinder can be analyzed with two integrals if the heights are uniform. The interpretation of the integral is contingent upon the units assigned to the quantities involved.
  • Understanding of double integrals in calculus
  • Familiarity with definite integrals and their applications
  • Knowledge of geometric dimensions and their implications in integration
  • Basic concepts of solid geometry and volume calculation
  • Explore the application of triple integrals for calculating volumes of irregular solids
  • Study the relationship between integrals and geometric dimensions in calculus
  • Learn about the use of Jacobians in changing variables for multiple integrals
  • Investigate real-world applications of double integrals in physics and engineering
Students and professionals in mathematics, physics, and engineering who seek to deepen their understanding of integrals and their applications in calculating area and volume.
transgalactic
why there are a case where double integral could calculate area
and in other case
it could calculate a volume.
an integral should do only one thing
not both??
for what characteristics it could used to calculate area,
for what its volume
Hi transgalactic! :smile:
It depends what you're integrating.
(did you have something specific in mind?)
For example, with an irregular solid you'd probably need 3 integrals, but with say an irregular cylinder (like a cookie-cutter :wink:), all the heights are the same, so you only use 2 integrals . :smile:
A definite integral (single, double, are whatever) just represents a number. It's only when we give it context by attaching dimensions (e.g., feet, cm, lb) to the quantities involved does it represent area or volume or work or what-have-you.
A single integral could represent an area, volume, length, probability, or any number of other concepts, depending on what we have decided to use for units. It's similar for double integrals.
What makes you think that an integral is supposed to do only one thing?
