Equations of Motion for Three Coupled Pendula with Low Spring Constant k
  • Thread starter Thread starter ekkilop
    Coupled
The discussion focuses on deriving the equations of motion for three coupled pendula (A, B, and C) with mass m and length L, connected by springs with a low spring constant k. The approach involves calculating the kinetic energy (T) and potential energy (U) of the system, assuming small oscillations. The potential energy is expressed as U = (mgb/2)(θ₁² + θ₂²) + (b²κ/2)(θ₁ - θ₂)², where κ represents the spring constant. The use of the Lagrangian method is recommended for deriving the equations of motion due to the absence of degenerating forces.
  • Understanding of Lagrangian mechanics
  • Familiarity with potential and kinetic energy in oscillatory systems
  • Knowledge of small angle approximations in pendulum motion
  • Basic concepts of coupled oscillators
  • Study the Lagrangian formulation of mechanics
  • Explore the dynamics of coupled oscillators in classical mechanics
  • Learn about the effects of degenerating forces on oscillatory systems
  • Investigate the mathematical modeling of spring-pendulum systems
Students and educators in physics, mechanical engineers, and researchers interested in the dynamics of coupled oscillatory systems.
ekkilop
Derive the equations of motion for three identical pendula A, B and C, of mass m and length L coupled together (A to B and B to C) with two identical springs of low spring constant k.
Can't quite appreciate the forces acting on these pendula as they all should be dependent of each other. Any help would be appreciated.
I would tackle the problem by first stating the kinetic energy and potential energy of the pendula.
[tex] T=\frac{1}{2}m\left(b\dot\theta_{1} \right)^2 + \frac{1}{2}m\left(b\dot\theta_{2} \right)^2 + \cdot\cdot\cdot[/tex]
Assuming small oscillations with the usual cosine/sin substitutions:
[tex] U=\frac{mgb}{2}\left(\theta^2_{1}+\theta^2_{2} \right) + \frac{b^2\kappa}{2}\left(\theta_{1}-\theta_{2} \right)^2[/tex]
U is for a two pendula system, you should be able to figure out how to add in another pendulum.
From here you can use the Lagrangian which should be rather straight forward since we don't have any degenerating forces.
At least that would probably be the way I would tackle it.
Thanks a bunch. That did the trick =)
Of pure curiosity, what would happen if we in fact had a degenerating force?
15K
  • · Replies 31 ·
