Thread Closed
Exhaust gas heat exchanger calculations
Share Thread Thread Tools
May6-09, 10:47 AM   #1
Hi Guys newbie here.
Im trying to design a CHP system in which an engine with steady exhaust gas flow uses a heat exchanger to heat water for use around the home (central heating, washing water etc). The engine specifics are to be developed but i need to be able to size a heat exchanger so i can develop the system. The exhaust composition is largely air but obviously steam is present. The water is standard, chalky mains water.
Now the hot tank of water can be sized accordingly, and the flow rate specified by using a pump or pumps. How would you go about setting up a spreadsheet using standard heat transfer equations to model the system? Ive got pretty basic heat transfer knowledge (i.e. newtons law of cooling and heat transfer coefficients).
Any help would be great appreciated :)
Kindest regards
Steve
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
May6-09, 11:40 AM   #2
Recognitions:
Gold Membership Gold Member
Conservation of energy, i.e. the energy taken out of the exhaust gas equals the energy recovered for your hot water system.
Heat available in the exhaust is mass flow, multiplied by the specific heat capacity (is this a Diesel or petrol engine?), multiplied by the temperature difference over the heat exchanger (so exhaust outlet temperature minus whatever you can cool down to). Then you need to look at what return temperature and flow rate you want for your hot water system, and size a cooler for that capacity and required effectiveness.
May6-09, 11:50 AM   #3
OK. But how would i then go about sizing a heat exchanger? Assume an exchanger efficiency? How much energy is recovered over what size of heat exchanger? thanks in advance.....
May6-09, 12:02 PM   #4
Recognitions:
That can be pretty tricky; there are people who do just that as a profession. If you have a Heat Transfer book, there should be some empirical data in there. My particular book has a section in there. Work through some stuff like that, and you should be in the ballpark.
May6-09, 12:13 PM   #5
any way i can avoid the cost of a book!???
any pointers for appoximate calcs? im not after any particular accuracy....
May6-09, 05:17 PM   #6
Recognitions:
Homework Helper Homework Help
I'd suggest purchasing one unless you want to go into the heat exchanger business. There are hundreds of manufacturers of all kinds of heat exchangers. A simple plate type might work well and be economincal for this application.
http://en.wikipedia.org/wiki/Plate_heat_exchanger
The first thing to do is write down what you know about your process, such as:
Fluid being cooled:
Pressure:
Allowable pressure drop though HX:
Inlet temp:
Fluid being heated:
Pressure
Inlet temp:
Most manufacturers can then size a heat exchanger for you and make a recommendation. Manufacturers also sometimes have software on the net you can use to size one yourself.
Take a look for manufacturers here:
http://www.thomasnet.com/nsearch.htm...sec=prodsearch
Here's a typical manufacturer's web page that includes selection software:
http://www.geaphena.com/
Thread Closed
Thread Tools
Similar Threads for: Exhaust gas heat exchanger calculations
Thread Forum Replies
Heat exchanger selection General Engineering 1
Heat Exchanger Thermal Calculations Mechanical Engineering 2
heat exchanger Materials & Chemical Engineering 0
Is this even possible? (heat exchanger problem) Mechanical Engineering 4
Heat exchanger question. Engineering, Comp Sci, & Technology Homework 0
