Thread Closed
Direction of Magnetic Field for a Charged Rotating Disc
Share Thread Thread Tools
May6-09, 12:23 PM   #1
The question actually asks for the equation for the magnetic field for the rotating disc; but all I'm after is the direction of the magnetic field.
2. Relevant equations
None were given; but I've been using:
[tex] \nabla \times \vec{E} = -\frac{\partial \vec{B}}{\partial t}[/tex]
3. The attempt at a solution
When I use the above equation I get two components to the magnetic field: [tex]\hat{r}[/tex] and [tex]\hat{\theta}[/tex]. That doesn't really make a lot of sense to me. What am I missing?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
May6-09, 12:40 PM   #2
The cross product will give you the direction.
May6-09, 12:44 PM   #3
Recognitions:
Homework Helper Homework Help
Quote by Rahmuss View Post
The direction of the field depends on where you are measuring it at. If you measure the field along the axis of the disk (presumably the z-axis--- where [itex]\theta=0[/itex]), then the field should point along the axis (assuming the disk is uniformly charged). It may help you to note that [itex]\hat{z}=\cos\theta\hat{r}-\sin\theta\hat{\theta}=\hat{r}[/itex] along the z-axis.
May6-09, 01:29 PM   #4
waht - Thanks. And that part I understand just fine. There is only a z-component of the electric field, so when I do a cross product, I get both an r-component and a theta-component.
gabbagabbahey - So the way you're describing it, the magnetic field seems to come up at the center of the disk, and then moves out and around to the bottom circling back up along the z-axis again?
May6-09, 01:58 PM   #5
Recognitions:
Yes, the field lines are very similar to those of a circular loop of current. After all, the disk can be thought of as a superposition of a very large number of thin circular loops of various radii.
Thread Closed
Thread Tools
Similar Threads for: Direction of Magnetic Field for a Charged Rotating Disc
Thread Forum Replies
Magnetic field above a thin charged disc Advanced Physics Homework 8
Generation of a magnetic field by rotating a charged ring Classical Physics 2
direction of magnetic field and direction of current General Physics 16
A rotating magnetic field. Does any one know how this is done? Electrical Engineering 2
Elecrtic field of Charged disc Introductory Physics Homework 11
