How Do You Calculate Mass and Volume in Different Scenarios?
The discussion focuses on calculating mass and volume using density values for various substances, specifically copper, aluminum, iron, lead, water, seawater, mercury, and gasoline. To find the mass of a 10.0 cm³ cube of copper, one multiplies its density (8.96 g/cm³) by the volume, resulting in 89.6 grams. For identifying an unknown substance with a mass of 51.5 g and a volume of 50.0 cm³, users should calculate the density and compare it to known values. Additionally, to determine the dimensions of a cubic tank holding 1,000.0 kg of water, one must understand that 1 kg equals 1,000 cm³, leading to a tank dimension of 10 meters per side.
  • Understanding of density calculations (mass/volume)
  • Familiarity with unit conversions (grams to kilograms, cm³ to m³)
  • Knowledge of common material densities (copper, aluminum, etc.)
  • Basic mathematical skills for multiplication and unit manipulation
  • Study density calculations in detail using various materials
  • Learn about unit conversions, particularly between metric units
  • Explore the properties and densities of additional substances
  • Practice solving real-world problems involving mass and volume
Students in physics or chemistry, educators teaching density concepts, and professionals in fields requiring material identification based on mass and volume calculations.
terpsgirl
What is the mass of a 10.0 cm cubed cube of copper?
i know that (g/cm cubed)= copper = 8.96 but I'm not sure how to tackle this problem.
also...
If I have 51.5 g of a 50.0 cm cubed volume of one of these substances, which would it be?
Alumininum 2.70 mass density, Copper 8.96, Iron 7.87, Lead 11.4, Water 1.00, Seawater 1.03, Mercury 13.6, Gasoline 0.680...How do I determine which one it is?
A cubic tank holds 1,000.0 kg of water. What are the dimensions of the tank in meters? Whats the reasoning?
Thanks so much!
Chemistry news on Phys.org
For the first two, the units of measure should give you a pretty good clue.
Mass is measured in grams and that's what you want. You know the density (g/cm^3) and you know the volume (cm^3). If you multiply the density by the volume, the cm^3 will cancel out and leave you with grams.
Same principle for the second, except you know different variables. Set your equation up so you your answer is in the right format for density. Match your density to the choices.
For the third, you have to know how your units of measure are defined. 1 gram is equal to the mass of 1 cm^3 of water. 1000 g (1 kg) is equal to (1000 cm)^3, or (10m)^3. The only challenge here is remembering to multiply your units of measure before you cube them.
25K
15K
10K
