Multiplying Variables: How to Multiply (3√2x)(3√2x) | Homework Help
  • Thread starter Thread starter Stratosphere
    Variables
The discussion revolves around the multiplication of expressions involving square roots, specifically the expression (3√2x)(3√2x) and a related expression (2-√(x-1))(2-√(x-1)). Participants are exploring how to correctly multiply these expressions and simplify the results.
  • Participants are attempting to clarify the notation used in the original expression and whether it involves cube roots or square roots. There are discussions about the properties of square roots and how to apply them in multiplication. Some participants are also questioning the setup of the problem and exploring how to handle variables within radicals.
The discussion is ongoing, with participants providing insights into the multiplication process and questioning the clarity of the original problem statement. There is a focus on understanding the multiplication of square roots and the implications of the properties of numbers involved.
There is some confusion regarding the notation used in the expressions, particularly whether they are meant to represent square roots or cube roots. Additionally, participants are addressing the challenges of formatting mathematical expressions in the forum.
Stratosphere
How would I multiply this together? (3[tex]\sqrt{2x}[/tex])(3[tex]\sqrt{2x}[/tex])
I can't seem to be able to figure out how to multiply them, i keep getting an answer that is too short.
What do you get?? And are those supposed to be cube roots or 3 times a square root?
3 times a square root. Sorry if it’s not clear.
That's fine. So what did you get?
Well you should be able to say what [itex]\sqrt{2x}\sqrt{2x}[/itex] is just from the definition of square root! And I'm sure you know what (3)(3) is!
But are you absolutely sure it is [itex](3\sqrt{2x})(3\sqrt{2x})[/itex]? That's seems a peculiar way to write a very simple question. [itex](\sqrt[3]{2x})(\sqrt[3]{2x})[/itex] is a much more reasonable (and slightly harder) question.
Let me rephrase the question. I want to know how to multiply somthing like
(2-[tex]\sqrt{x-1}[/tex])(2-[tex]\sqrt{x-1}[/tex]), in other words, how to square a side that has variables in a radical.
After i did this out i got
-4[tex]\sqrt{x-1}[/tex]+x+3
And what could be wrong with that?
Commutative and associative properties will let you group the like factors together. You see each factor is squared. 3[tex]\bullet[/tex]3[tex]\bullet[/tex][tex]\sqrt{2x}[/tex][tex]\sqrt{2x}[/tex], and then just one or two more steps if any.
EDIT: While trying to edit this, to fix the LARGE dots representing multiplication, the typesetting formatting tool is gone; those should really be small dots as can be common for showing multiplication operation. I do not have many of these tags memorized for TEX.
Let me continue:
(3)(3)[tex]\sqrt{2}[/tex][tex]\sqrt{2}[/tex][tex]\sqrt{x}[/tex][tex]\sqrt{x}[/tex]
edit: this time, the forum will NOT permit me to put in the missing square root of x. It is present in the message edit field, but will not appear in the resulting forum message.
