| Thread Closed |
Greens |
Share Thread | Thread Tools |
| May6-09, 04:45 PM | #1 |
Greens
verify greens for the integral (xy^2 i - x^2y j) dot dr over c, where c = y = x^2 from (-1,1) to (1,1). Evaluate both sides independantly to achieve the same answer 2. Relevant equations 3. The attempt at a solution so i took the partials and got -2xy - 2yx = -4xy, shouldnt it equal o. |
| May6-09, 04:58 PM | #2 |
Why should it equal zero? What exactly is the question asking you to check?
| May6-09, 06:54 PM | #3 |
I'm confused by this. Green's theorem relates the integral around a closed path to the integral of the expression you give over the region bounded by the closed path.
"c = y = x^2 from (-1,1) to (1,1)" is not a closed path and so does not bound a region. Did you intend to include the line from (1, 1) back to (-1, 1)? In any case that expression you give would be 0 only if the integral around the closed path were 0. |
| May6-09, 07:14 PM | #4 |
Greens
ya it does say "from -1,1 to 1,1 and the line segment from 1,1 to -1,1. sorry i didnt realize that was important
| May7-09, 06:18 AM | #5 |
Then I strongly suggest you revies Green's theorem!
| May13-09, 12:59 PM | #6 |
Recognitions:
Forgot [tex]d\vec{r}[/tex].
Use [tex]\oint_{C}\left( xy^2\hat{i} -x^2y\hat{j}\right)\cdot d\vec{r} = \oint_{C}\left( xy^2\hat{i} -x^2y\hat{j}\right)\cdot \left( dx\hat{i} +2x\, dy\hat{j}\right) = \oint_{C}xy^2\, dx -2x^3y\, dy[/tex] |
| May13-09, 01:40 PM | #7 |
oook check this
[tex]\oint[/tex]xy2dx - 2x3dy P = xy2 Q = 2x3y [tex]\int[/tex][tex]\int[/tex]6x2y - 2xy dy dx -1 < x < 1, x2<y<1 [tex]\int[/tex]-3x6 + x3 + 3x2 - x dx = 8/7 |
| Jun15-09, 08:42 AM | #8 |
Recognitions:
[tex] \oint_{C}xy^2\, dx -2x^3y\, dy = \int_{-1}^{1}\int_{x^2}^{1}\left( \frac{\partial }{\partial x}\left( -2x^3y\right) -\frac{\partial }{\partial y}\left( xy^2\right)\right) dydx[/tex] [tex]= \int_{-1}^{1}\int_{x^2}^{1}\left(-6x^2y-2xy\right) dydx = \int_{-1}^{1}\left[ y^2\left(3x^2+x\right)\right|_{y=1}^{x^2} dx[/tex] [tex]= \int_{-1}^{1}\left(3x^6+x^5-3x^2-x\right) dx=-{\scriptstyle \frac{8}{7}}[/tex]
| Thread Closed |
| Thread Tools | |
Similar Threads for: Greens
| greens theorem | Calculus & Beyond Homework | 2 | ||
| [SOLVED] Greens Functions | Calculus & Beyond Homework | 5 | ||
| greens theorem and cauchy help | Calculus & Beyond Homework | 0 | ||
| greens theorem: | Calculus & Beyond Homework | 5 | ||
| greens function | Differential Equations | 2 | ||
