Does anyone know how to do these two questions?
  • Thread starter Thread starter b_ball_gurl87
The discussion focuses on calculating the specific heat of a metal using the formula m1 * s1 * Δt1 = m2 * s2 * Δt2. Given a 10 g metal heated to 60°C placed in 50 g of water, which experiences a temperature rise of 22.5°C, the specific heat of the metal can be determined. The specific heat of water is a known constant, typically 4.18 J/g°C. The final temperature of the system is assumed to be 47.5°C, allowing for the calculation of the metal's specific heat. Additionally, the discussion touches on calculating moles of KClO3 needed to produce 2.8 L of O2 at STP.
  • Understanding of specific heat capacity and its formula
  • Knowledge of the concept of thermal equilibrium
  • Familiarity with the properties of water, specifically its specific heat
  • Basic stoichiometry for calculating moles of substances
  • Learn how to apply the specific heat formula in different scenarios
  • Research the properties and specific heat values of common metals
  • Study the stoichiometric calculations for gas production in chemical reactions
  • Explore the concept of thermal equilibrium in closed systems
Chemistry students, educators, and professionals involved in thermodynamics and heat transfer calculations, as well as those studying stoichiometry in chemical reactions.
b_ball_gurl87
a piece of metal with mass 10 g is heated to a temperature of 60C. when the metal is placed in 50 g water, the temperature of water rises by 22.5 C. what is the specific heat of metal?
how many moles of KClO3 are needed to form 2.8 L of O2 measured at STP?
if you noe, please msg me :P
Chemistry news on Phys.org
The overall energy level (in this case, heat) of the two substances combined stays constant. The heat is just redistributed between them, so:
[tex]m_1 \ast s_1 \ast \Delta t_1 = m_2 \ast s_2 \ast \Delta t_2[/tex]
(mass times specific heat times change in temperature)
To solve this, you need to know five of the variables:
The mass of the metal is given, the mass of the water is given.
The change in temperature of the water is also given.
The specific heat of water is most likely given in your book. It's a number that's used often enough you ought to either memorize it or program it as one of your user constants (provided you have a good calculator).
That gives you four of your variables and you need one more. The original temperature is given and you need the change in temperature. So, you need the final temperature, as well. You haven't been given enough information unless you assume the water started at standard room temperature (25 degrees). This is probably a pretty safe assumption to make if the actual room temperature wasn't given.
The final temperature of both the metal and the water has to be the same, so the final temperature is just the original temperature of the water plus the change in temperature of the water.
With that info, you can find the fifth variable and solve for the sixth - the specific heat of the metal. (If it's an elemental metal or a common alloy, you should even be able to determine what the metal is from its specific heat - look in your book or in a chemical handbook).
  • · Replies 19 ·
11K
