Thread Closed
Help solving nonhomogeneous de
Share Thread
May7-09, 01:12 AM   #1
Hey guys just asking for a bit of help to get me on the right track.
I have the non homogeneous de 4y" + 4y' + y = 3*x*e^x, which also has some inital conditions y(0)=0 and y'(0)=0. but i only need help with getting the particular solution.
Tried method of constant coefficients and it didnt want to work for me.
I end up using: y(p) = A*t*e^t which doent seem right when i substitute in y'(p) and y"(p) into the original equaltion.
Tried method of variation of parameters and i dont think that worked either as in the end i got y(p) = 0.
So far i get the auxilary eq: r^2 + r + 1/4 = 0
=>(r + 1/2) = 0
thus r1 = r2 = -1/2
so y(h) = c1*e^-1/2*t + c2*t*e^-1/2*t
i just need help as to what method i would use to get a the particular solution y(p). from there its gravy :)
thanks in advance
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
May7-09, 01:36 AM   #2
Recognitions:
Homework Helper Homework Help
With respect to the method of constant coefficients: usually whenever there's a polynomial involved, you should include terms for all powers up to the order of the polynomial. In your case, you have y = (constant)*(polynomial)*(exponential), but you only included the linear term in your polynomial - you left out the constant term. Go back and try y(x) = A(x+B)e^x.
May7-09, 01:45 AM   #3
Quote by diazona View Post
So obvious now you have pointed that out.
Im all over it like a bad rash now
Thanks heaps
May7-09, 01:56 AM   #4
Recognitions:
I've made that mistake many times myself... ODEs can be annoyingly tricky.
Thread Closed
Similar discussions for: Help solving nonhomogeneous de
Thread Forum Replies
Solving Nonhomogeneous Heat Equation with Fourier Transform Calculus & Beyond Homework 2
Nonhomogeneous 2nd order DE Calculus & Beyond Homework 1
nonhomogeneous DEs Differential Equations 3
Second Order Nonhomogeneous Calculus & Beyond Homework 4
2nd ODE nonhomogeneous Introductory Physics Homework 1
