Thread Closed
Compound gear train problem (WHY IS IT SO HARD!!!!!)
Share Thread Thread Tools
May7-09, 09:00 PM   #1
I need to calculate the angular acceleration of the fan at 2600 RPM (motor speed) depicted by figure 4.
2. Relevant equations
Sum(torques with respect to input) = (torque applied by motor)-(torque load from output shaft with respect to gear ratios)
THEN
Sum(torques with respect to input) =( sum of intertia's with respect to input and gear ratio's) x (angular acceleration of input shaft)
3. The attempt at a solution
Now my problem is that there are no moments of inertia given for the gears in the system. I'm assuming the torque load on the output shaft caused by the fan is a form of torque lost due to air resistance of the fan. Thus the faster the fan the higher the torque lost.
Basic formulation I'm using is:
THEN
Then I can use the (angular acceleration of input shaft) to find the angular acceleration of the output shaft using gear ratios.
My main problem is that I dont have all the intertia's of the gear system! So do I simply ignore the other moment of inertia's or is there a correct way of calculating them!!!
A little advice / help please!!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
May13-09, 10:36 AM   #2
No need to calculate the moment of intertia of gears.
It is small compare to the work loss from the other side.
If you really need to calculate that.
We know the gears sizes d=N/P (N:number of teeth ,P:diametial pitch, d:diateter)
The same P is required to compose the gears.
We known the center distance c = (d59+d21)/2 =(d55+d21)/2
P59=P21, P55=P21 => d59:d21 = 59:21
Then we can calculate the diameter of gears by finding the hand book.
There is a fixed specification by product.
Then see what material you use.
Having say so ,you DO NOT need to calculate the intertial .lol
Thread Closed
Thread Tools
Similar Threads for: Compound gear train problem (WHY IS IT SO HARD!!!!!)
Thread Forum Replies
Worm Gear/ Spur Gear Mechanical Engineering 1
Gear Design Problem Mechanical Engineering 19
Gear Train Ratio Calculation Mechanical Engineering 11
Gear problem Classical Physics 3
