Register to reply
Trigonometry problem
by amanara
Tags: trigonometry
Share this thread:
amanara
#1
May8-09, 03:04 AM
P: 11
1. A fire in a building B is reported on telephone to two fire stations P and Q , 20 km apart from each other on a straight road. P observes that the fire is at an angle of 60 degrees to the road and Q observes that it is at an angle of 45 degrees to the road. Which station should send its team and how much will its team have to travel?
2. An aeroplane flying horizontally 1 km above the ground is observed at an elevation of 60 degrees. After 10 seconds , its elevation is observed to be 30 degees. Find the speed of the aeroplane in km/hr.
explain also
Phys.Org News Partner Mathematics news on Phys.org
'Moral victories' might spare you from losing again
Fair cake cutting gets its own algorithm
Effort to model Facebook yields key to famous math problem (and a prize)
deferro
#2
May8-09, 03:13 AM
P: 49
You are triangulating distances, so you need a function that returns a distance.
Building B is the location of fire p, a distance p'Q and p'P in a straight line (the road the trucks need to use). You need to triangulate the three points on the surface first with something like p'Q = 60(pQ) for a radial measure of the location of firestation Q, and similarly for P.
Then p and p' are measuring functions, and you use the overhead projection onto BPQ on the ground (Cartesian) plane after doing the same with that. You don't "need" pi but it's a handy symbol in circular functions. 60deg is pi/3
IOW 20k is the distance function value for PQ which is the hypotenuse of right triangle BPQ
amanara
#3
May8-09, 07:27 AM
P: 11
Tell me how to solve both of them and the answers.
al2521300
#4
May8-09, 07:59 AM
P: 3
Use the law of sines. The law of sines for a triangle is just the relation that the ratio of the sine of an angle by the length of the opposite side of the triangle is a constant for each triangle. With this law you can calculate the size of both sides of the triangle, or quicker you can just compare the two sides in question to see which one is bigger.
Let PB be the distance from fire station P to building B. Let QB be the distance from Q to B, then
[tex]\frac{PB}{sin(60\,degrees)}=\frac{QB}{sin(45\,degrees)}[/tex]
[tex]\frac{2PB}{\sqrt{3}}=\frac{2QB}{\sqrt{2}}\Rightarrow PB=QB\frac{\sqrt{3}}{\sqrt{2}}>QB[/tex]
which is what is to be expected from the angles.
The second problem is done in a similar manner. Calculate the distance it has moved, and just divide by the time to get the average speed.
Register to reply
Related Discussions
A trigonometry problem..... Introductory Physics Homework 1
Trigonometry problem Precalculus Mathematics Homework 16
Another trigonometry problem Precalculus Mathematics Homework 6
Trigonometry problem Introductory Physics Homework 5
