Simple category theory isomorphism
The discussion revolves around the isomorphism between the product of an object A with a terminal object 1 in category theory, specifically exploring the relationship between A and A × 1. Participants are examining definitions, projections, and the conditions under which this isomorphism holds, with a focus on the subtleties involved in category theory.
  • Farley proposes that A × 1 is isomorphic to A, outlining a proof involving projections and compositions of arrows.
  • Some participants question the definitions used, particularly the meaning of '1' and whether the discussion assumes a specific type of category, such as an abelian or Grothendieck category.
  • Farley clarifies that he is working within a "vanilla category" where products are assumed to exist, and '1' refers to a terminal object.
  • Another participant asserts that the map from A to A × 1 is unique by the definition of direct products, challenging the characterization of the projection as a Cartesian inclusion.
Participants express differing views on the definitions and assumptions underlying the discussion, particularly regarding the nature of the category and the interpretation of the terminal object. There is no consensus on these foundational aspects.
Limitations include the lack of clarity on the specific category being discussed and the assumptions about the existence of products and terminal objects. The discussion also highlights the potential ambiguity in the terminology used.
farleyknight
Hey all,
Okay, let me give this a wack. I want to show that [itex]A \times 1[/itex] is isomorphic to [itex]A[/itex]. I'm aware that this is trivial, even for a category theory style. However, sticking to the defs and conventions is tricky if you aren't aware of the subtleties, which is why I'm posting this. So here goes:
Consider objects [itex]A[/itex] and [itex]A \times 1[/itex]. From the object [itex]A \times 1[/itex] we have the arrows [itex]\pi_1 : A \times 1 \to 1[/itex] and [itex]\pi_A : A \times 1 \to A[/itex]. Now we will also consider [itex]A[/itex] as a product in the following way: let [itex]\rho_1 : A \to 1[/itex] be the projection from A to 1, since this will always exists. Also, let [itex]\rho_{A \times 1} : A \to A \times 1[/itex] be the "projection" (really just a 'Cartesian inclusion'?) from A to [itex]A \times 1[/itex]
To the expert: this last step I'm unsure about. It is obvious what it is from a set theory POV but from the category perspective it's not clear how the arrow might arise naturally (or legally).
The rest of the proof is pretty straight forward: Since we have two products [itex]A[/itex] and [itex]A \times 1[/itex] we can compose [itex]\rho_{A \times 1} \circ \pi_A[/itex], which is a round trip on [itex]A \times 1[/itex], so it must be the identity. Similarly for [itex]\pi_A \circ \rho_{A \times 1}[/itex] must be the identity on A. And since these maps are unique and in opposite directions, they must be inverses, so we have a bijection between the two.
Thanks,
- Farley
You need to explain your hypotheses. What does x mean? Direct product - well that means you're not talking about a generic category? And what is 1? A category does not have an object that one calls '1' in general. Are you assuming an abelian category? Serre category? Grothendieck cateory?
Sorry about that.. I shouldn't have tried to post late at night.
Anyways, I'm just working with a vanilla category. However, as far as I've read, products are assumed, when they exist. And '1' is just a terminal object. So, instead, I would proceed:
Let [itex]\mathcal{C}[/itex] be a category with [itex]1 \in Obj(\mathcal{C})[/itex] a terminal object and both [itex]A \times 1, A \in Obj(\mathcal({C}))[/itex] as products in this category. (Can you do that?)
BTW this is proved on this guy's blog: http://unapologetic.wordpress.com/2007/06/27/categorification/ but he doesn't quite explain how f is both a projection and the unique map required by the product.. I thought I'd try a slightly different proof, hoping I didn't make a mistake.
By the definition of direct product, there is a map A -> Ax1 as defined and it is unique (and it is not cartesian inclusion since there is no reason to suppose A and 1 are sets).
  • · Replies 0 ·
  • · Replies 26 ·
  • · Replies 0 ·
