Register to reply
Find allowable axial compressive load
by jrizzle
Tags: allowable, axial, compressive, load
Share this thread:
jrizzle
#1
May11-09, 11:51 PM
P: 1
Find the allowable axial compressive load for a 3in by 2in by .25in 17 S-T aluminum-alloy angle 43in long. It acts as a pin-ended column.
Assume: Factor of safety = 2.5
Least radius of gyration, r = .43
Area = 1.19 in^2
2. Relevant equations
17 S-T gives modulus of elasticity of:
E = 10,600 ksi
some formulas (im sure im missing some)
f.s. = P_u/P_all
Stress = P/A
3. The attempt at a solution
P_all = P_u/f.s = P_u/2.5
im really confused. i dont understand how there could be 3inX2inX.25in and then 43in long for one. then there is a weird area of 1.19 in^2
can someone help me with this? they didnt give a diagram either
Phys.Org News Partner Science news on Phys.org
Physical constant is constant even in strong gravitational fields
Montreal VR headset team turns to crowdfunding for Totem
Researchers study vital 'on/off switches' that control when bacteria turn deadly
minger
#2
May12-09, 07:59 AM
Sci Advisor
P: 1,498
I'm assuming one leg is 3", the other is 2" and the bar is 1/4" thick. The whole thing is then 43" long. Is this an Euler beam buckling problem?
PhanthomJay
#3
May12-09, 08:05 AM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 6,050
The most important formula you are missing is the formula for ultimate buckling stress. Are you familiar with it? Also, regarding the area of the angle, do you know what a 3 x2 x 1/4" angle looks like? See the site below for a cross section. The thickness is 1/4", and the legs are 3" and 2" , respectively. The cross sectional area works out to 1.19 in^2. The length is 43 inches (into the plane of the page). http://www.engineersedge.com/angle_unequal.htm
mathmate
#4
May12-09, 01:59 PM
P: 366
Google "Euler buckling" and you will have a lot of relevant reading to get you started.
nvn
#5
May12-09, 10:10 PM
Sci Advisor
HW Helper
P: 2,124
jrizzle wrote: "stress = P/A; P_all = P_u/f.s."
Excellent, jrizzle. That's correct. And your first equation, quoted above, can be written P_u = sigmacr*A. Therefore, can you find in your text book a formula for sigmacr or P_u? Notice the hints given by PhanthomJay and mathmate. Hint: P_u might sometimes be called Pcr.
Register to reply
Related Discussions
Explain compressive load General Engineering 2
Determine maximum allowable weight of a load supported by chains Mechanical Engineering 4
Determine the maximum allowable weight of a load supported by chains. Engineering, Comp Sci, & Technology Homework 1
Slenderness ratio and axial load of steel question..pls help Mechanical Engineering 9
Statics: Axial Load and Strain Introductory Physics Homework 4
