Dynamics - pendulum hanging on a cord, determine T in cord
The discussion focuses on determining the tension (T) in a pendulum cord when the angle (Ф) is 0°. The user initially attempted to solve the problem using radial and transverse force decompositions but encountered issues with the sign of the angular velocity squared. A key correction was identified: the equation for the sum of forces in the transverse direction should include a negative sign, leading to the correct relationship of -mg*sinФ = mL*α. This adjustment aligns the solution with the principle of work and energy, confirming that ω² = 2g/L(1 - cosФ).
  • Understanding of pendulum dynamics and forces
  • Familiarity with angular motion and acceleration concepts
  • Knowledge of the principle of work and energy in physics
  • Basic calculus for integrating motion equations
  • Study the principles of pendulum motion and energy conservation
  • Learn about the derivation of angular motion equations in physics
  • Explore the impact of forces on pendulum dynamics using simulations
  • Review common mistakes in force decomposition in mechanics problems
Physics students, educators, and anyone interested in classical mechanics, particularly those studying pendulum motion and force analysis.
srvs
A pendulum of mass m and length L is released
from rest at an angle Ф to the vertical. There is no
friction and g = 9.81 m/s2.
Determine the normal force in the cord when Ф =
0°.
http://img87.imageshack.us/my.php?image=pend.jpg
Note that phi is giving in degrees.
2. The attempt at a solution
Decomposing in the radial direction, and taking T as the tension in the cord:
[tex]\sum F_{r} = m*a_{r} = - T + mgcos\Phi = m(-L\omega[/tex]²) (1)
Decomposing in transverse direction:
[tex]\sum F_{\theta} = m*a_{\theta} = mgsin\Phi = m(L\alpha)[/tex]
[tex]\alpha = d\omega/d\Phi * d\Phi/dt = d\omega/d\Phi * \omega[/tex]
So:
[tex]mgsin\Phi = m(L(d\omega/d\Phi)\omega)[/tex]
[tex]sin\Phi d\Phi = (L/g) \omega d\omega[/tex]
When the angle is phi, the angular velocity is 0. When the angle is 0, the angular velocity is omega.
[tex](L/g) \int^{\omega}_{0}\omega d\omega = \int^{0}_{\Phi} sin\Phi d\Phi[/tex]
[tex]\omega^{2} = -2(g/L)(1 - cos \Phi)[/tex]
So I end up with a negative term for my angular velocity square. So I can't calculate my angular velocity. Even if I use this omega square and stick it into (1), the resulting equation for T is wrong.
This was easily solvable with the principle of work and energy, however this method specifically is required.
Can someone give me a headsup of where I've gone wrong? Thanks!
I think the problem is a simple sign one.
Your equation for Sum of F_Theta has mg*sinPHI = mL*ALPHA. But if you're measuring PHI from the downward-vertical, this equation is false. It should read:
-mg*sinPHI = mL*ALPHA.
The reason? Well, for PHI > 0, the pendulum is to the right of the lower diagonal, sinPHI is positive, but the pendulum bob will have negative acceleration.
This resolves the problem and will yield the same answer as the energy method for OMEGA^2: 2m/L (1 - cos phi).
Yeah, just a sign thing.
edit: Oops ignore previous question, I understand it now. Thanks a lot for your help!
  • · Replies 17 ·
  • · Replies 17 ·
