How Is Force Calculated When an Object Hits the Ground?
  • Thread starter Thread starter cd19
The discussion revolves around calculating the force exerted by an object when it strikes the ground after falling from a height. The object has a mass of 4 kg and falls from a height of 10 m, taking 20 ms to come to rest after impact.
  • Participants discuss the speed acquired by the object during free fall and the implications for calculating force. There are questions about understanding the relationship between mass, acceleration, and the change in velocity over time.
Some participants have provided insights into the calculations needed to determine force, including references to the equations of motion. There is acknowledgment of confusion regarding the interpretation of the time interval involved in the problem. While one participant claims to have found a force value, there is no explicit consensus on the correctness of this value.
Participants note potential misunderstandings regarding the time unit and the nature of the problem, indicating that clarity on these points is necessary for accurate calculations.
cd19
An object of mass 4 kg is released from rest at a height of 10 m. After striking the ground it take 20ms before it is brought to rest. Assuming that the object exerts a constant force F on the ground during the 20ms interval then what is the magnitude of F?
Having trouble understanding the question, would appreciate if someone could put it into perspective.
Welcome to PF.
Consider the speed that the object has acquired by falling 10m.
F = m*a = m*Δv/Δt = Δmv / Δt
I have found the speed acquired by falling 10m to be 14 ms (m*g*h=1/2*m*v^2). but I still can't comprehend what to do next.
Remember what force is. F=ma, with a the acceleration as you know. Once the object hits the ground it goes from 14m/s to 0s in 20ms. This means it is decelerating. It has mass and it is decelerating that sounds like the two essential components to calculate the force. The basic question is what is its deceleration?
you know m,
you know v,
you know Δt ...
ah i see, I've been reading the question wrong, I'll put it down to tiredness. I kept thinking 20 ms was 20 ms^-1. how stupid. I found the force to be 2800N, which i feel is correct. thanks very much for the quick reply's.
Looks right.
Good Luck.
  • · Replies 23 ·
  • · Replies 31 ·
