Why Do My Contour Integration Arguments Lead to an Imaginary Result?
  • Context: Graduate
  • Thread starter Thread starter jack5322
    Integration
The forum discussion centers on the evaluation of a contour integral that leads to an imaginary result due to incorrect argument selection in the integrand. The user factored the integrand as x-2/3(1-x)-1/3 and restricted the arguments incorrectly, leading to confusion about the contour's direction and the residue at infinity. The correct approach involves recognizing the need for proper branch selection and understanding that the residue at infinity introduces additional minus signs in the calculations. Ultimately, the correct result is derived using the residue theorem and proper contour orientation.
  • Complex Analysis, specifically contour integration
  • Residue Theorem and its applications
  • Understanding of branch cuts and principal branches in complex functions
  • Familiarity with polar coordinates in complex analysis
  • Study the Residue Theorem in detail, focusing on examples involving residues at infinity
  • Learn about branch cuts and how to properly define them in complex functions
  • Explore contour integration techniques with varying orientations and their implications
  • Practice problems involving complex integrals with multiple branch points
Mathematicians, physics students, and anyone involved in complex analysis who seeks to deepen their understanding of contour integration and residue calculations.
jack5322
http://ocw.mit.edu/NR/rdonlyres/Mathematics/18-04Fall-2003/FACBFB25-64E5-4AA8-8868-F623EDA94CE8/0/assignment3.pdf
This link on problem 4 is troubling me. What I want to do is evaluate it, but I first need to find the arguments on the segments above and below the cut. To do this I started off by factoring x^-2/3 out of the integrand, to get x^-2/3(1-x)^-1/3. After this, I restrict the argument of x in between pi and -pi, and for 1-x between 0 and 2pi. After doing out the algebra we find that the cut line is exactly between 0 and 3 on the real axis. Defining them in their respective local polar coordinates, we get on the top to be -2pi/3 and on the bottom zero for each argument. I know this is where I messed up because after factoring out the exp(-2pi/3) from the segment on the top, and calling the contour [1-exp(-2pi/3)]I and applying the residue theorem, i get the answer is imaginary! This has to be wrong, but why is it that my arguments are wrong, Any help would be GREATLY appreciated, so if you know anything about this stuff, then please help!
Why did I get it wrong, though, I can see why their example is right, but what is the correct way to do it if you do it my way, i.e. the x^-2/3 is restricted to pi-negative pi, and the (1-x)^-1/3 is the principle branch i.e zero to 2pi?
I'm afraid that would take me a while to figure out. Actually it would take me a while to go through the one in AoPS as well but I may do so but probably not in time to help you. Sorry.
I find the correct answer using your conventions for the branches. You get 2 pi i*(-residue at infinity) divided by [1-exp(-2 pi i/3)]
The residue at infinity depends on your choice of the branches, it is exp(-pi i/3) (apart from a possible minus sign). Together with the factor i that makes a sin in the denominator.
thank you so much count iblis! and you too squidsoft! It all makes sense now, I used the -1 for my res at infinity.
Thanks again!
wait a minute, i get the right answer, but it is negative, where did i go wrong now?
Is the contour around the two branch points moving in the clockwise or the anti-clockwise direction?
i chose anticlockwise
nevermind i got the problem.
Then the contour integral will be minus 2 pi i times the residue at infinity. But note that, by definition, the residue at infinity has itself a minus sign in its definition: residue at infinity of f(z) at infinity is the residue at zero of -1/z^2 f(1/z).
The reason for the two minus signs is as follows. If you have a contour integral I and a contour integral IR over a contour with radius R for large R, then we have:
IR - I1 = 2 pi i sum of residues inbetween the two contours ----->
I1 = -2 pi i sum of residues inbetween contours + IR
Then if we take the limit of R to infinity, we can write this as:
I1 = -2 pi i sum of residues outside the contour in I1
if we include the so-called residue at infinity which then must be defined as:
2 pi i residue at infinity = - Lim R to infinity of IR
Then the limit of IR for R to infinity can be obtained by considering the conformal transormation Z = 1/W. You then get the contour integral of
f(1/W) 1/W^2 dW
Note that the minus sign in the dZ = -1/W^2 dW compensats for the fact that the contour would be traversed in the opposite direction.
So, the end result is that you must take 2 pi i times the residue at zero of 1/z^2 f(1/z)
  • · Replies 19 ·
