Which catalyst is the best for the reaction betweeen Aluminum metal and HCl?
The discussion centers on identifying the most effective catalyst for the reaction between aluminum metal and hydrochloric acid (HCl). Participants evaluate four compounds: copper sulfate, sodium chloride, potassium iodide, and magnesium sulfate. The consensus leans towards copper sulfate as the preferred catalyst, supported by experimental evidence. The chemical reaction is represented by the equation 2Al(s) + 6HCl(aq) -> 2AlCl3(aq) + 3H2(g).
  • Chemical reaction mechanisms
  • Catalysis principles
  • Properties of transition metal compounds
  • Basic understanding of acid-metal reactions
  • Research the role of copper sulfate in catalysis
  • Investigate the properties of transition metals as catalysts
  • Explore the effects of different salts on acid-metal reactions
  • Study the kinetics of aluminum and hydrochloric acid reactions
Chemistry students, educators, and researchers interested in catalysis and reaction mechanisms involving metals and acids.
chemlover
1. I need to know which compound out of Copper Sulfate, sodium chloride, potassium iodide and magnesium sulfate will be the best catalyst for the reaction between ALuminum metal and Hydrochloric acid.
2. The chemical equation is : 2Al(s) + 6HCl(aq) -> 2AlCl3(aq) + 3H2(g)
3. I believe that copper sulfate would do the trick because my teacher showed us an experiment in which copper sulfate was used but I am not sure.
How does the listed salts acts as catalyst for the reaction and what property of the salts give rise to it being a better catalyst?
11K
16K
9K
  • · Replies 16 ·
9K
9K
