Quantum friction due to vacuum energy
The discussion revolves around the concept of quantum friction, particularly in relation to the Casimir effect and the role of vacuum energy in generating lateral forces between two uncharged plates. Participants explore the theoretical underpinnings and implications of this idea, while also addressing the challenges of understanding and discussing it at an advanced undergraduate level.
  • One participant expresses difficulty in finding comprehensive resources on quantum friction and seeks guidance on discussing the topic at an advanced level, noting their background in quantum mechanics but not in quantum field theory (QFT).
  • The participant describes a scenario involving virtual photons and their Doppler shifts, questioning how these shifts relate to momentum transfer between two uncharged plates.
  • Another participant challenges the analogy between the Casimir effect and classical friction, suggesting that the Casimir effect is a conservative force while classical friction is not.
  • A different participant raises concerns about the validity of the quantum friction concept, referencing a recent paper that claims the magnitude of the force may be zero, suggesting uncertainty about the existence of such an effect.
  • The original poster acknowledges the controversy surrounding the topic and expresses a willingness to engage with it despite their limited understanding, citing the structure of their course as a factor in their choice of topic.
Participants exhibit disagreement regarding the validity and nature of quantum friction, with some questioning its existence and others exploring its theoretical implications. There is no consensus on the topic, and various perspectives are presented.
The discussion highlights limitations in understanding due to the complexity of quantum field theory and the challenges of relating vacuum energy to observable effects. The participants also note the dependence on definitions and the unresolved nature of the claims regarding quantum friction.
ballzac
Hi,
I am writing an essay on quantum friction (the hypothetical force based on the casimir force). I am having trouble finding information on this concept. Wiki does not have a page on it, nor does Britanica. I have found only three Journal articles on the subject. There is more stuff about a quantum description of friction, but I need to write this specifically on the role of vacuum energy in providing a lateral force on two uncharged plates. I'm hoping someone can help guide me to where I can get an overview of this topic, as I'm having trouble understanding it.
I need to be able to discuss it at an advanced undergraduate level. I have studied quantum mechanics, but not QFT. I will obviously need to borrow a little from QFT, but cannot provide detailed explanations based on QFT because I haven't studied it and only have a short time to complete the essay.
One aspect I am having trouble with is this:
One explanation talks about a moving plate, with virtual photons striking from random angles. In the rest frame of the plate, the photons traveling in the same direction as the plate (according to OUR rest frame) are redshifted, and the ones traveling in the opposite direction are blueshifted. This causes momentum to be transferred to the plate, causing it to slow down.
Now, the hypothesised quantum frictional force is only thought to exist between TWO plates, so this doesn't happen with one plate. This makes sense, because the vacuum should look the same in the rest frame of the plate, as it does in our rest frame, so there can't be a force from the vacuum that accelerates a plate. However, clearly this symmetry does not exist when there are two plates.
The thing I don't understand though, is how the presence of a second plate can affect the behaviour of the other plate. The only way I can think of it, is if the momentum of the photon is being transferred FROM ONE PLATE TO ANOTHER. This is clearly the case, but how does that relate to the description of the doppler shift of the virtual photons? Are the virtual photons originating at the surface of the other plate? I don't see why they should. They are a manifestation of the vacuum energy itself, so I don't see how a single virtual photon can exchange momentum BETWEEN the two plates. Mind you, we are talking about UNCHARGED plates, so there are no photons associated with an electromagnetic field of the material itself.
In class, we were taught about the casimir effect, and asked to write out essay on one of the 'related topics' given in class, so I gather that the explanation for the Casimir effect given in class may be able to be used to explain quantum friction...perhaps. The explanation was that there are more modes of the vacuum energy outside of the plates than inside because the plates are nodes and therefore require integer values of photon energy, whereas outside the plates the number of modes is uncountable.
Hope I've been clear on all this, and hopefully someone can shed a little light on this topic. Thanks. :)
Sounds weird to me. The Casimir effect is a conservative force, classical friction is not. So the analogy makes no sense to me.
What are you trying to describe, the ordinary Casimir effect, or something else?
First, I think it's a very bad idea to take something you don't understand (for example, something that requires QFT to understand if you haven't had QFT) as a subject of an essay.
Second, it's not clear there even is such an effect: see http://arxiv.org/abs/0810.3750" of 6 weeks ago where they claim that in an exact calculation the magnitude of the force is zero.
Yes, I have read that paper, but I think controversy is okay because it gives me something to discuss. I agree that it is not ideal to write an essay on a topic that I don't understand, but I have little choice. The topics include topological defects, dark energy, and condensed matter systems, among others, and all require relating the topic to vacuum energy. Some might be easier to understand than others, but I don't know much about any of them, and thought it best to just pick a topic and get going with it.
The particular unit I am taking seems to be pretty much aimed at stretching the students. The professor who runs the unit knows that we have not learned QFT. We generally get a quick overview on a topic (usually over the course of a one hour lecture) and then have to solve-problems, give a talk, write an essay etc. within a couple of weeks. Other topics we have covered have are variational calculus and the principle of least action, and number theory.
Thanks for the input.
  • · Replies 29 ·
  • · Replies 46 ·
  • · Replies 33 ·
  • · Replies 46 ·
  • · Replies 17 ·
