Prove recursive sequence to be contractive
  • Thread starter Thread starter glomar
    Sequence
The discussion revolves around a recursive sequence defined by x(1)=1 and x(n+1)=1+1/x(n). Participants are tasked with proving that the sequence is contractive, specifically that abs[x(n+2)-x(n+1)]<= 1/2 abs[x(n+1)-x(n)] for all n.
  • Participants discuss proof by induction, examining base cases and induction hypotheses. Some explore the implications of the recursive definition, while others question the correctness of their reasoning and the relevance of certain inequalities.
There is ongoing exploration of the sequence's properties, with some participants providing guidance on how to approach the proof. Multiple interpretations of the problem are being discussed, particularly regarding the contractive nature of the sequence and the necessary conditions to establish it.
Participants note the importance of establishing that x(n) remains greater than or equal to 1 and that the sequence converges towards a limit. There is also mention of formatting suggestions for clarity in mathematical expressions.
glomar
Consider the sequence (x(n)) defined recursively by x(1)=1 and x(n+1)=1+1/x(n).
Prove that abs[x(n+2)-x(n+1)]<= 1/2 abs[x(n+1)-x(n)].
Proof by induction.
For n=1, abs(x(3)-x(2))<= 1/2 abs(x(2)-x(1))
abs(-1/2)<=1/2 abs(1)
1/2=1/2
So, for n=1 is true.
Suppose that n=k and that
abs[x(k+2)-x(k+1)]<= 1/2 abs[x(k+1)-x(k)]. We have to show that
abs[x((k+1)+2)-x((k+1)+1)]<= 1/2 abs[x((k+1)+1)-x(k+1)].
I'm not sure if this is correct. If so, how can I continue?
Thanks in advance!
Looks OK, but you need to use the fact that
[tex]x_{n + 1} = 1 + \frac{1}{x_n}[/tex]
Have you looked at the numbers in this sequence?
x1 = 1
x2 = 1 + 1/1 = 2
x3 = 1 + 1/2 = 3/2
x4 = 1 + 1/(3/2) = 5/3
x5 = 1 + 1/(5/3) = 8/5
and so on.
Yes,
So far what I have is
abs((x(n+2)-x(n+1))= abs(1/x(n) - 1/x(n+1)). I think what I have to prove by induction is
x(n)>=1.
So, for n=1 , x1=1 is true. Assuming n=k and x(k) is true, I have that
x(k+1)= 1+ 1/x(k).
Since x(k)>= 1, 1/x(k) < 1. So 1+ 1/x(k) >=1.
I'm I in the right direction?
Thanks!
You were before, but now you aren't.
As it turns out, xn >= 1 for all n, but that's not what you are asked to prove. You are supposed to show that the sequence is contractive, which if I'm remembering correctly means that successive pairs of sequence elements get closer and closer together. Specifically, you are asked to prove that for the given sequence, |xn+2 - xn+1| <= 1/2 * |xn+1 - xn|.
Note: your work would be much easier to read if you use | | for absolute values and subscripts for your sequence terms (using sub and /sub pairs, with both tags surrounded by square brackets []).​
You have established the base case; i.e., that |x3 - x2| <= 1/2 * |x2 - x1|.
You are assuming in your induction hypothesis that the following is true:
|xk+2 - xk+1| <= 1/2 * |xk+1 - xk|.
You now need to show that this is true:
|xk+3 - xk+2| <= 1/2 * |xk+2 - xk+1|.
It's easy enough to establish that
|xk+3 - xk+2| = |1/(xk+2) - 1/(xk+1)|, using the recursive definition for xn+1 in terms of xn.
Now there are only two things left to do: 1) do some easy algebra on the fractions on the right side of the equation above; 2) establish (via induction?) that xn * xn+1 >= 2 for all n >= 1.
Thank you for the typing suggestions. I'm still trying to put the subscripts.
Here is my proof about
For n=1 , x1 * x2 = 2 so it's true.
Suppose that xn * xn+1 >= 2 is true. Then,
xn+2 * xn+1 =
(1 + 1/xn) xn+1 =
xn+1 + 1 =
(1 + 1/xn) + 1 =
1/xn + 2 >=2
Hence,
xn+2 * xn+1 >= 2 for all n>=1.
This implies that
1/(xn+2 * xn+1) <= 2 for all n>=1.
So,
|xk+3 - xk+2| = |1/(xk+2) - 1/(xk+1)|=
|xn+1-xn+2|/(xn+2 * xn+1)|<= |xn+1-xn+2|/2
Therefore,
|xk+3 - xk+2|<= |xn+1-xn+2|/2
How did I do?
Thanks again!
  • · Replies 16 ·
