What is the volume of an air bubble in water at a depth of 50m?
The problem involves calculating the volume of an air bubble in water at a depth of 50 meters, considering the effects of pressure and temperature changes on the bubble's volume using the ideal gas law.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of the ideal gas law and how pressure and temperature affect the volume of the bubble. There are attempts to set up ratios based on the gas law, and some participants question the validity of the ideal gas law in this context.
There is ongoing exploration of the relationships between pressure, volume, and temperature. Some participants have provided guidance on setting up the equations correctly, while others are still working through the implications of their assumptions and calculations.
Participants note the need to approximate initial pressure due to lack of specific information, and there is mention of the pressure at the surface being one atmosphere.
soopo
The problem is at
http://dl.getdropbox.com/u/175564/volumePressureTemperature.JPG
I know the equation for ideal gases
pV = nRT
and
the definition of pressure
p = F / A
The change in T is 10.
V_i = 1 cm^3
We need to first consider how the change in Temperature affects
the depth at which the bubble is.
It will goes up because the volume of the bubble increases.
The increase in Volume causes the boyonce force to increase.
Thus, the net force in f direction is zero at both depths:
F_boyonce - F_gravity = 0
g( m_Water - m_airBubble ) = 0
There is a linear relation between p and T if we assume the
situation for ideal gases.
I have apparently ignored some critical part.
It seems that the ideal Gas equation is not valid here.
The right answer is 6.2cm^3 that is (f).
Sure it is--it's all you need for this problem. How does the pressure change? The temperature? Use the ideal gas law to determine how the volume changes. (Set up ratios.)
I have the following
V1 / V2 = [tex]\frac { T1 / P1 } { T2 / P2}[/tex]V1 / V2 = [tex]\frac {290(p1 + 5atm)} {p1 * 300}[/tex]
= 290/300 + 1450/(P1 * 300)
The problem is now P1 which is the initial pressure.
It seems that we need to approximate it, since we do not know it.
You have the ratios a bit backwards. Start with this:
P1V1/T1 = P2V2/T2
You should know it. What's the pressure at the surface?
P1V1/T1 = P2V2/T2
It is one atm :)
I get the following result
V1 / V2 = 6 * 290/300
= 5.8
whrere 290 kelvins is 17 celsius and 300 kelvins is 27 celsius.
Taking inverse
V2 / V1 = 0.17
where V2 is the volume at the surface.
Both answers seem to be wrong: I cannot get 6.2.
I have likely ignored some small volume.
Are you sure it's not 6*300/290 ?
soopo said:
It is one atm :)
Good. :wink:
= 5.8
Once again, you're flipping things around somehow.
Start with this:
(P1V1)/T1 = (P2V2)/T2
Then solve for V1.
I finally got the right answer.
V1 = P2 V2 T1 / T2 P1
= 6 * 30 / 29
= 6.2
Thank you for your answers!
  • · Replies 25 ·
