How Does Poisson's Equation Apply to Plasma Physics?
  • Context: Graduate
  • Thread starter Thread starter peterjaybee
    Plasma
This discussion focuses on the application of Poisson's equation in plasma physics, specifically for a plasma composed of electrons and protons. The equation presented is \frac{1}{r^{2}}\frac{d}{dr}\left(r^{2}\frac{d\varphi\left(r\right)}{dr}\right) = \frac{2}{\lambda_{D}}\varphi\left(r\right), with the solution given as \varphi\left(r\right) = \frac{e}{4\pi\epsilon_{0}r}exp\left(-\frac{\sqrt{2}r}{\lambda_{D}}\right) as r approaches infinity. The user, Peter, initially struggled with integrating the equation but later found a method by substituting R(r) = r \varphi (r), leading to a homogeneous second-order differential equation. This approach clarified the path to the solution.
  • Understanding of Poisson's equation in the context of plasma physics
  • Familiarity with differential equations, particularly second-order homogeneous equations
  • Knowledge of the Debye length, \lambda_{D}, in plasma physics
  • Basic calculus skills, including integration and the chain rule
  • Study the derivation of solutions for second-order differential equations
  • Explore the physical significance of the Debye length in plasma behavior
  • Learn about boundary conditions in solving differential equations in physics
  • Investigate the applications of Poisson's equation in other areas of physics
Students and researchers in plasma physics, physicists working with electromagnetic fields, and anyone interested in the mathematical modeling of plasma behavior.
peterjaybee
Hello,
In my plasma physics book, poissons equation in relation to a plasma made up of electrons and protons is given as
[tex]\frac{1}{r^{2}}\frac{d}{dr}\left(r^{2}\frac{d\varphi\left(r\right)}{dr}\right) = \frac{2}{\lambda_{D}}\varphi\left(r\right)[/tex]
The solution of this equation when phi(r) tends to 0 for r tending to infinity is
[tex]\varphi\left(r\right) = \frac{e}{4\pi\epsilon_{0}r}exp\left(-\frac{\sqrt{2}r}{\lambda_{D}}\right)[/tex]
How do you get to this solution? I have tried multiplyin both sides by r^2, then integrating w.r.t. r, by parts, but I cannot get any further than that.
Regards,
Peter
The simplest thing to do would be to substitute using:
[tex]R(r) = r \varphi (r)[/tex]
Then you can rewrite it as:
[tex]\frac{1}{r}\frac{d}{dr} \left( r^2 \frac{d \varphi}{dr} \right) = \frac{2}{\lambda_d}R[/tex]
You can continue from here by performing the chain rule to place the left hand side in terms of [tex]R[/tex].
EDIT: Nevermind, I made a mistake earlier on, fixed now. Sorry for any confusion.
I have now got a homogeneous 2nd order differential equation and from that an auxillary equation, which is beginning to take the form of the answer. Thanks
  • · Replies 0 ·
