Why is the change in electric potential leading to a negative work value?
The discussion revolves around the concept of electric potential and potential energy in the context of a problem involving work done when moving a charge. Participants are exploring the relationship between electric potential, potential energy, and the work required to move a charge in an electric field.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Some participants question the distinction between electric potential and potential energy, suggesting that the original poster may have misunderstood their definitions. Others explore the implications of moving a charge and how it relates to changes in potential energy and work done.
The discussion is active, with participants providing insights into the definitions of electric potential and potential energy. There is an ongoing examination of the mathematical relationships involved, particularly regarding the calculation of work and the change in voltage. Some participants are attempting to clarify misconceptions while others are exploring the implications of their findings.
There appears to be confusion regarding the definitions and relationships between electric potential, potential energy, and work, which may stem from differing interpretations of lecture materials. The problem context involves calculating changes in potential energy and understanding how these relate to work done on a charge.
Ry122
http://users.on.net/~rohanlal/elec.jpg
for question b, wouldn't there be no change in electric potential since
electric potential for a particular point is determined by the sum of the electric potentials for
each particular charge about that point, and if a charge is moved to point p
and the eq for electric potential is kq/r then that charge would be 0 since r would be 0.
for question b, wouldn't there be no change in electric potential...
In b) they are asking for the change in potential energy. This is not the same as asking for the electric potential - i.e. the voltage.
The change in potential energy is going to be expressed as the work required to move the charge.
For b) then what you want to explore is work given by ...
W = qΔV
The voltage at ∞ is 0, so ... ΔV = simply the voltage at P.
According to my lecture notes electric potential is the same as potential energy.
the answer to this problem requires the initial electric potential of the system which is found by
http://users.on.net/~rohanlal/pot.jpg
to be subtracted from 3.0x10^-6
which gives a final answer of - 1.89 x 10-2
but i don't understand why this is the case
Your lecture notes are wrong, then...
Mathematically, electric potential is
[tex]V = k\frac{q}{r}[/tex]
whereas electrical potential energy is
[tex]U_E = k\frac{q_1 q_2}{r}[/tex]
It's not subtracted.
The Work is the charge times the change in voltage potential.
What they want is Work.
And if you multiply the charge by the Voltage, then you get the answer indicated.
  • · Replies 22 ·
  • · Replies 23 ·
