WolframAlpha guide on electrical engineering
The discussion revolves around the functionalities of WolframAlpha as a computational tool specifically for electrical engineering applications. Participants explore various features, including dimensional analysis, solving equations, logic gates, calculus, and plotting capabilities, while sharing tips and experiences related to the software.
  • Homework-related
  • Some participants highlight WolframAlpha's ability to perform dimensional analysis and unit conversions relevant to electrical engineering.
  • Others discuss the tool's capacity to solve equations, including differential equations, without needing to specify variables explicitly.
  • Participants mention the software's support for complex numbers and phasors, including algebraic manipulation and conversion between forms.
  • There are claims about WolframAlpha's functionality in calculating resistor color codes and parallel resistor combinations.
  • Some users share links to specific WolframAlpha queries that demonstrate its capabilities in designing filters and calculating inductance.
  • Discussion includes the availability of a mobile app and comparisons between the app and the web version, with questions about advantages and user experiences.
  • One participant raises a question about recommending WolframAlpha to students interested in physics and computing systems modeling.
  • Another participant mentions an alternative application, "Algeo.apk," as a useful tool for similar tasks.
Participants generally agree on the usefulness of WolframAlpha for electrical engineering tasks, but there are varying opinions on its advantages over other tools and applications. Some discussions remain unresolved, particularly regarding the comparison of the mobile app to the web version and the recommendation for students.
Limitations include potential differences in functionality between the mobile app and the web version, as well as varying user experiences that may depend on individual needs and contexts.
This discussion may be useful for electrical engineering students, educators, and professionals interested in computational tools for problem-solving and modeling in physics and engineering contexts.
waht
Introduction:
WolframAlpha is a freely available computational engine that can supplement already existing software such as mathematica, maple, mathlab, or excel. The purpose of this mini-guide is to go over some of its functionality with emphasis on electrical engineering.
www.wolframalpha.com
Dimensional analysis:
WolframAlpha recognizes many common units. It will simplify dimensions and scale units. For example,
Code:
farad * henry
will generate [time]^2
Code:
0.01 uF to pF
will generate 10,000 pF or 10 nF
WolframAlpha also can tap its database to pull up a conversion formula from the context
Code:
convert 25 MHz to meters
will convert the frequency to wavelength 12 meters
Code:
find energy in 100 uF at 10 KV
will give energy in a capacitor,
or to find inductance to resonate with 10 nF capacitor at 100 Khz; just say that
Code:
find inductance for 10 nF at 100 KHz
output 253 nH
Also if you haven't memorized resistor color bands already, you can still look them up
Code:
resistor yellow purple red
output: 4.7KComplex numbers and phasors:
Working in polar form is supported in W|A. By typing an impedance in rectangular form
Code:
30 + 45i
we are quickly given its magnitude and phase of 54, and 56 degrees
and likewise, we can indicate a phasor in polar form with an exponential e
Code:
e^(i pi)
generates -1
we can also manipulate phasors algebraically
Code:
100 e^(i 45 deg) + 25 e^(i 30 deg)
output: magnitude = 124, phase = 42 deg
indicate degrees with “deg” otherwise W|A will interpret it in radians.Solving equations:
To solve [itex]x^2 - 2x + 1= 0[/itex], enter the equation as it is
Code:
x^2 - 2x + 1 = 0
output x = 1
and W|A solves it. Don't even have to specify the variable to be solved.
Solving systems of equations is just as easy,
[tex]v_1 + v_2 + v_3 = 4[/tex]
[tex]v_1 - v_2 = 10[/tex]
[tex]v_1 - 3v_2 + 5v_3 = 8[/tex]
simply type
Code:
v1 + v2 + v3 = 4, v1-v2 = 10, v1 - 3v2 + 5v3 = 8
output v1 = 23/3, v2 = -7/3, v3 = -4/3
just make sure that the equations are separated by a comma.
Differential equations are supported as well. An nth number of apostrophes indicates an nth derivative, and proceed as before. For example to solve
[tex]\frac{d^2y}{dx^2} - \frac{dy}{dx} - 2y = 0 \indent y(0) = 1, y'(0) = 2[/tex]
enter the code as follows,
Code:
y'' – y' - 2 y = 0, y(0) = 1, y'(0) = 2
and we get a solution y = e^2x as well as a plot that can be saved in pdf format, and printed out.We can also maximize and minimize
Code:
max 1 - x^2
finds maximum of 1Logic gates and boolean algebra:
Converts number bases,
Code:
binary 1111101 to hex
= 7d
We can also work with boolean expression in WolramAlpha, for example
Code:
(x or y) and (x or !y)
generates a truth table:http://img200.imageshack.us/img200/9384/truthtable.gif
a schematic with logic gates, and even simplifies the expression to a minimal form
http://img268.imageshack.us/img268/3233/scehmatic.gif
Here is the supported syntax:
Code:
NOT = !
OR = ||
AND = &&
NAND
NOR
XOR
More on calculus:
W|A can perform basic calculus
take derivatives:
[tex]\frac{d}{dt} cos(t)[/tex]
Code:
derivative cos(t)
do integration:
[tex]\int \frac{1}{x+1} dx[/tex]
Code:
integrate 1/(x+1) dx
and take Laplace and Fourier transforms:
[tex]\mathcal{L}(x^2), \mathcal{F}(e^x)[/tex]
Code:
laplace x^2
Code:
fourier  e^x
Plotting:
If you want to graph a transfer function for instance,
[tex]H(s) = \frac{s+10}{s^2 + 4s + 8}[/tex]
enter:
Code:
 graph (s + 10)/(s^2 + 4s + 8)
and here we have
http://img32.imageshack.us/img32/9715/graph.gif Conclusion:
WolframAlpha uniquely combines different tools into a one freely available package and that expands our tool box. This mini-guide doesn't cover all of W|A, it merely touches upon features that can be used in electrical engineering, for more information visit their examples page
http://www28.wolframalpha.com/examples/
also, W|A is said to expand in the future, enabling more functionality, and tools.
Thanks for putting that together, what. I've stickied this thread to help us learn how to utilize W|A.
Any further posts in this thread should be about tips on how to use W|A and its features. Discussions about W|A and its implications for eductaion, etc., belong in a different thread, like this one: https://www.physicsforums.com/showthread.php?t=307686
Resistor color codes
Code:
output: 4.7K
The inverse operation works also. Type this for input:
Code:
resistor color 4.7k ohms
... and the output is an image of the resistor with the correct color bands:
View the full W|A output here:
http://www5f.wolframalpha.com/input/?i=resistor+color+4.7k+ohms&asynchronous=false&equal=Submit
Check out the WolframAlpha app for the iPhone and iPod Touch. Its pretty awesome!
Remember when the WA app cost $50? They thought because it's better than any scientific calculator could be, they could charge that much, but you know, no one would pay that much so they made it $2.
is there any advantage over the ipod app vs the standard web version?
Would you guys recommend wolfram alpha to a student who is interested in learning more about physics and modeling physics within computing systems? I have a small bit of experience with mathlab, and am hoping to be on the go as I do this (iPad, Android, etc.)
I have "Algeo.apk" in my galaxy tab, it is a wonderful application in small scale.
  • · Replies 18 ·
  • · Replies 18 ·
