How Does Time Dilation Affect Aging in Orbit?
The discussion revolves around the effects of time dilation on aging for an astronaut who orbited the Earth 22 times at an altitude of 160 km. Participants are examining the time difference experienced by the astronaut compared to someone on the Earth's surface, referencing a claim made by the press regarding aging less by 2 millionths of a second per orbit.
  • Participants are calculating the astronaut's orbital speed and the corresponding time dilation effects using relativistic equations. Some question the accuracy of the gamma factor used in the calculations, while others suggest that gravitational time dilation must also be considered.
There is an ongoing exploration of the calculations related to time dilation, with some participants providing alternative perspectives on the necessary factors to consider. While some guidance has been offered regarding the calculations, there is no explicit consensus on the correctness of the initial calculations or the interpretation of the press report.
Participants note that the problem may involve both special and gravitational time dilation, and there is a discussion about the relevance of the Earth's rotation in determining relative speed. The original claim of 2 microseconds per orbit is referenced as a point of contention.
fredrick08
in 1962 a person orbited the Earth 22 times, the press stated that each orbit he aged 2millionths of a second less, then if he remained on earth.
a.assuming he was 160km above the earth, in a circular orbit, determine the time difference between on Earth and the orbiting astronaut for 22orbits.
V=root(GM/R)
tau=gamma*t
v=root(6.67x10^-11*5.98x10^24/6.37x10^6+160x10^3)=7815.5m/s
distance(circumference)=2*pi*r=2*pi*(6.37x10^6+160x10^3)=4.1x10^7m
t=4.1x10^7/7815.5=5249.7s
gamma =approx (1+.5*(7815.5/3x10^8))=1.000000001
tau=gamma*t=5249.719894s
tau-t=3.563x10^-6s? is this rite, because, i can't see anywhere i have gone wrong... used exact answers in all my calculations. i guess that is kind of close to 2x10^-6s
V=root(GM/R)
tau=gamma*t
What was the relative speed of the astronaut relative to Houston? I think you have to factor in the rotation of the Earth here.
AM
V=root(GM/R)
tau=gamma*t
I think you might have to fix up your gamma, the calculation for gamma should be
gamma = 1 / SQRT(1 - v^2/c^2)) which is going to be slightly different from your answer.
The formula for t = t0*gamma and you should get hopefully the dilated time if everything
is relative.
ok thanks
You are looking at only part of the time dilation. The astronaut ages less because of special relativistic and gravitational time dilation.
Fortunately, you don't need to know either special or general relativity to answer this question because you have already been given the answer to this question. All you need to compute is how much time passed for a person on the surface of the Earth and use the given relativistic time dilation to compute how much time passed on-orbit.
We can see that this is non-relativisitic speed so we can approximate gamma by 1 + v^2/2c^2. I think that is where you went wrong. You were approximating by 1+v/2c.
The orbital speed is 7816 m/sec as you found. So the orbital period is 5.25 x10^3 seconds as you have found. 22 periods amounts to 1.14 x 10^5 seconds or about 32 hours. I don't see the 22 orbits in your calculation.
But the Earth is also rotating, and during that period a person on the Earth is moving at a speed of 460 m/sec. So the relative speed (depending on the direction of the orbit) is a range from (7816 + 460) m/sec to (7816 - 460) m/sec. (8276 m/sec to 7356 m/sec)
From this I get the maximum time dilation to be:
[tex]t'-t = 4.2 x 10^{-5}[/tex] sec
The minimum time dilation is about 3.4 x 10^-5 seconds.
AM
You are forgetting gravitational time dilation. A person 160 km above the surface of the Earth experiences less gravitational time dilation than someone on the surface of the Earth.
There is no reason to calculate the time dilation at all because the problem already gives that answer: 2 microseconds per orbit.
The first rule of being a scientist should be: don't to believe what you read in the press about science.
I think the question is asking the student to determine whether the press report was right. It appears to be right.
AM
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 35 ·
