Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Number Theory
Reply
image Average minimum tries for prime factorization Share It Thread Tools Search this Thread image
Old May24-09, 06:24 PM                  #1
Loren Booda
Loren Booda's Avatar
Loren Booda is Offline:
Recognitions:
PF Contributor PF Contributor
On average, at least how many factors must one try dividing a number N by to decompose it into primes?
Old May24-09, 07:04 PM       Last edited by CRGreathouse; May25-09 at 01:57 AM..            #2
CRGreathouse
CRGreathouse is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Average minimum tries for prime factorization
If you are dividing by sequential primes starting from 2, and you test the cofactor with a primality test after you find each factor, you're asking about the distribution of the second-smallest prime factor of a random integer. In particular, you want the number of primes up to that number.
A good answer would involve the extended Dickman function; see
http://cr.yp.to/bib/1996/bach-semismooth.pdf
An easier answer would involve harmonic numbers, since the 'probability' of finding an n-bit factor in a large number is about 1/n.
An off-the-cuff estimate would be "around n^(1/4) to n^(1/3)".
Old May25-09, 01:57 AM                  #3
CRGreathouse
Recognitions:
I'm not entirely sure about this, but I hacked together a program to calculate this for you based on the paper cited above. It suggests that the average size (median exponent) of the second-largest prime factor of a random integer N is around N^0.282.
Old May25-09, 02:55 PM                  #4
Loren Booda
Recognitions:
Originally Posted by CRGreathouse View Post
...you're asking about the distribution of the second-smallest prime factor of a random integer. In particular, you want the number of primes up to that number.
Bravo! - but why the second-smallest in particular? Could you give me an example of this result?
Thanks much for the computation also. I guess it is based on a prime approximation formula.
Old May26-09, 02:03 AM                  #5
CRGreathouse
Recognitions:
I'm not sure how to explain; it's obvious to me.
Let's say you have n = p * q * ... * r * s. You find the factor s, but n/s is still composite. You find the factor r, but n/ (r * s) is still composite. Then you find a number of other factors, but the cofactor is still composite. Then you find the factor q, and n / (s * r * ... * q) is prime, so you stop factoring. The last prime you had to factor out is the second-smallest.
It was a very hairy calculation using numerical root-finding, table lookup, a complicated approximation function, and more. It used the extension of Dickman's function from the paper I linked to.
There were so many steps in the process I'm not sure the result is correct! I may have made a mistake along the way. But it seems to be in about the right range, so I'm reasonably sure I have it.
Old May26-09, 10:30 PM                  #6
Loren Booda
Recognitions:
Your first approximation is really on the cuff. Can you tell how you conceived it?
Thank you for explaining your initial response in more detail. The distribution now seems sensible to me.
You prove yourself to be quite an adept and patient mathematician. The praise here belongs to you.
Old May27-09, 12:07 AM                  #7
CRGreathouse
Recognitions:
My guess that the second factor was between the fourth and third root, on average, was simply a result of experience with factoring numbers. There was no math involved there.
The n^0.282 approximation was based on the Bach-Peralta asymptotic formula G, which I hope I implemented properly. It's complicated.
image image
Reply
Thread Tools
Similar Threads for: Average minimum tries for prime factorization
Thread Thread Starter Forum Replies Last Post
Algorithm for prime factorization saadsarfraz Calculus & Beyond 12 Jan28-09 03:16 PM
Prime factorization of rationals Dodo Number Theory 4 Jul6-08 07:57 PM
Prime factorization set: Zeth Set Theory, Logic, Probability, Statistics 2 Aug2-07 10:16 AM
Prime factorization, Exponents turdferguson Precalculus Mathematics 1 Mar25-07 03:45 PM
Prime factorization devious_ Number Theory 2 Oct27-04 02:57 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
