How to network two computers using dial up
  • Thread starter Thread starter okwatia
    Computers Network
This discussion focuses on networking two computers using a dial-up connection. Key considerations include the necessity of having a modem and determining the operating systems in use. The conversation highlights the importance of establishing TCP/IP settings and the potential for easier connections if the computers are already networked through the internet or a local network. Participants emphasize clarifying whether the computers are using separate phone lines or are directly connected via a phone line.
  • Understanding of dial-up modem functionality
  • Familiarity with TCP/IP configuration
  • Knowledge of Windows file sharing protocols
  • Basic networking concepts, including IP addressing
  • Research dial-up modem setup and configuration
  • Learn about TCP/IP settings for Windows operating systems
  • Explore Windows file sharing techniques
  • Investigate alternative networking methods for improved connectivity
This discussion is beneficial for network engineers, IT professionals, and anyone interested in setting up legacy dial-up connections between computers.
okwatia
I want to network two computers using dial up connection. I need help
Computer science news on Phys.org
First off, this should probably be in the Computer Science or Technology forum, not homework (unless this is a homework problem, in which case you should show your attempt at a solution). A mod will probably be by to move this to one of those forums.
Next off, do you have a modem? Are you actually dialing out? More importantly, which operating system are you actually using? Are you attempting to do windows file sharing? Set up TCP/IP?
If the two computers are already networked, either through the internet, or through a local network, and they have IP addresses, it might be a whole lot easier to connect through this medium instead.
Would these two computers use different phone lines to the Internet or do you mean that the two computers are connected to each other’s modem by a phone line?
  • · Replies 27 ·
