Question about SR and increasing mass
  • Context: Graduate
  • Thread starter Thread starter LennoxLewis
    Increasing Mass Sr
The discussion revolves around the implications of relativistic effects on mass and momentum during high-speed collisions in the context of special relativity. Participants explore how mass increases with velocity, the concept of impulse, and the conservation of momentum and energy in relativistic scenarios.
  • One participant suggests that as a spaceship approaches the speed of light, its mass increases, leading to a potential violation of impulse conservation during a collision.
  • Another participant clarifies that in the spaceship's own frame, time does not slow down for the observer, and emphasizes the need to use relativistic momentum in collisions.
  • A calculation is presented comparing classical and relativistic momentum conservation in a collision scenario involving a spaceship and a stationary object.
  • Questions arise regarding the definition and components of the four-momentum vector, specifically the term (γ+1)mc.
  • Clarifications are made regarding the specific case of equal mass in the collision and the implications of using different masses for the objects involved.
Participants present differing views on the implications of mass increase and the conservation of impulse, with some agreeing on the necessity of using relativistic principles while others raise concerns about generalizing specific cases. The discussion remains unresolved regarding the broader implications of these concepts.
Participants note that the calculations and definitions provided are specific to the scenario discussed and caution against over-generalizing results to other cases without considering different mass and velocity factors.
LennoxLewis
Let's say you're on a spaceship and you can accelerate to a speed very close to c. As your own time seems to slow down (relative to slow moving observers), your mass also increases.
I know that mass increases in the sense that one requires more energy to give the same acceleration, but does this also mean that your impulse increases ? I assume so. So, if your spaceship would crash into something when you're close to c, it would seem as impulse was violated because (assuming you slow down enough), the mass becomes close to the rest mass again? In that case, would one have to consider a relativistic version of the conservation of impulse?
Your own time doesn't seem to slow down. In your own frame you are at rest and therefore you will see the clocks of inertial frames moving with respect to you slow down. In a relativistic collision you will have to use relativistic momentum. Classically you would expect mass to be conserved during a collision, but relativistically this is not true.
Lets do the calculations both classically and relativistically.
A spaceship of mass m going at speed v=4/5c crashes into an object at rest with mass m. (everything is happening in the x-direction)
Classically:
[tex]mv+0*m=M_*u=(m+m)u \Rightarrow m\frac{4}{5}c=2mu \Rightarrow u=\frac{2}{5}c[/tex]
Relativistically:
Momentum as well as total energy is conserved. Total energy is given by [itex]E=\gamma m c^2[/itex] and momentum is given by [itex]p=\gamma mv[/itex]. Combining these into a 4-momentum vector for simplicity yields [itex]p_\mu=((\gamma+1)mc,\gamma m v,0,0)[/itex].
[tex] p_\mu p^\mu=-(\gamma+1)^2m^2 c^2+\gamma^2 m^2 v^2=-M_*^2 c^2 \Rightarrow M_*=\frac{4}{\sqrt{3}}m[/tex]
And
[tex] u=\frac{p c^2}{(\gamma+1)mc^2}=\frac{1}{2}c[/tex]
Don't forget that this object with which it collides has rest energy as well. Classically its energy would be zero but in relativity this is not so. The total energy as well as momentum is conserved.
Edit: I don't have a lot of time currently so I didn't explain the calculation very well. If you have any questions about it feel free to ask I will try to answer them at a later time.
Thanks a lot for the explanation, Cyosis! I do have a question: in the four-vector, where does the (y+1)mc term come from?
The 4-vector is defined as [itex]p_\mu=(E/c,\vec{p})[/itex]. With E being the total energy. Before the collision we have the energy of the rocket ship [itex]E_r=\gamma mc^2[/itex] and the energy (rest energy) of the object it collides with [itex]E_0=mc^2[/itex]. Therefore the total energy is given by [itex]E_r+E_0=\gamma mc^2+mc^2=(\gamma+1)mc^2[/itex]. Plug it into the definition of the 4-vector and one c will drop out.
It all makes sense now. Thanks again.
Note that the [tex]\gamma+1[/tex] is not a general term, but specifically for the case where the rocket collides with an object of equal mass. It is correct for this case, but please don't accidentally over-generalize to other cases.
Yes DaleSpam raises a good point. I used an equal mass for the the object to simplify the calculation, this however may not have been particular smart for didactic reasons. I emphasize the general 4-momentum is given by [itex]p_\mu=(E/c,\vec{p})[/itex]. Now imagine the object it collides to has mass [itex]\mu[/itex] instead. Then E becomes [itex]\gamma m c^2+\mu c^2=(\gamma m+\mu)c^2[/itex]. Therefore the 4-momentum becomes [itex]p_\mu=((\gamma m+\mu)c,p_x,p_y,p_z)[/itex]. Another thing that is important to realize is that if the object it collides with was originally in motion with a speed other than v then its gamma factor differs from the space ship's gamma factor!
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 33 ·
  • · Replies 23 ·
