Finding the force of friction acting on an object - static or kinetic friction?
The discussion centers on calculating the friction force acting on a 70kg carton subjected to a 300N force at a 15-degree angle below the horizontal. The coefficients of static and kinetic friction are 0.4 and 0.28, respectively. The correct approach involves using the coefficient of static friction since the carton starts at rest, leading to a calculated friction force of 289.9N, which corresponds to Fcos(theta). The normal force is determined to be 603N, and while the maximum static friction force is 241.2N, the actual friction force matches the applied force without causing motion.
  • Understanding of Newton's laws of motion
  • Knowledge of static and kinetic friction coefficients
  • Ability to resolve forces into components
  • Familiarity with calculating normal force in physics
  • Study the principles of static vs. kinetic friction in detail
  • Learn how to calculate normal force in various scenarios
  • Explore force decomposition techniques in physics problems
  • Investigate real-world applications of friction in engineering
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone involved in solving friction-related problems in practical applications.
kathyt.25
"A force of 300N is applied to a 70kg carton on a level floor at an angle of 15deg below the horizontal. The coefficient of static friction is 0.4 and the coefficient of kinetic friction is 0.28. Find the friction force acting on the carton."
I don't know which coefficient to use - static or kinetic. I know that static friction involves a stationary object, so a=0 and Fnet=0... and kinetic friction involves a moving object, so Fnet=ma. I would ideally look to solve for acceleration, to see if its a zero or non-zero number, but there are too many variables to just solve for "a".
Fnet=ma
**u=coefficient of friction
I broke up the forces into their components:
F(y) = n - W - F(y) = n - mg + Fsin(theta) = 0
F(x) = Fcos(theta) - f(friction) = ma
So, F(x)--> un = Fcos(theta) - ma
I know that if its static friction, F(x)=f.. and if its kinetic friction, F(x)>f
The answer is 289.9N, which is Fcos(theta), but when I solve for kinetic and static friction separately once I've found the normal, I don't get this answer at all. I'm assuming from the answer, that static friction is used, because that's why friction=Fcos(theta), so it doesn't move.
However, when I solve f(k)=u(k)*n = 0.28(603N)=167N
And f(s)=u(s)*n = 0.4(603N) = 241.2N
Both values of friction don't give me 289.9N,
Can someone help me out?
Thank you!
Assume that the block starts at rest, so we'll consider the coefficient of static friction. As a hint, the product of the normal force and coefficient of static friction only gives the maximum value of force possible, not necessarily the frictional force that acts. For example suppose I apply a force of 15 N in the x direction on a block of mass 300 kg. If we take the coefficient of friction to be 0.4 then F_f = (0.4)(300 kg)(9.8 m/s/s) = 1176 N. If this frictional force were to act the block would be accelerating; however, we know that it stays at rest. Therefore, we know the frictional force must be equal to the 15 N I apply. Hopefully this makes sense and helps you solve the problem.
