Net force on an object and contact force between objects
The discussion focuses on calculating the net force on three blocks (m1, m2, m3) in contact on a frictionless surface when a horizontal force of 17.9N is applied to m1. The net forces on m1 and m2 are determined using Newton's second law (Fnet = ma), yielding 3.14N for m1 and 6.61N for m2. The contact force between m1 and m2 is incorrectly calculated by subtracting the net forces instead of using the correct approach of analyzing the individual contact forces. The correct method involves setting the sum of contact forces equal to the net force acting on the respective block.
  • Understanding of Newton's laws of motion, particularly Newton's second law (Fnet = ma).
  • Basic knowledge of forces and contact forces between objects.
  • Ability to perform calculations involving mass, acceleration, and net force.
  • Familiarity with the concept of frictionless surfaces in physics.
  • Study the concept of contact forces and how they relate to net forces in multi-body systems.
  • Learn how to apply Newton's third law to analyze interactions between objects.
  • Explore examples of frictionless surfaces and their implications in physics problems.
  • Practice solving problems involving multiple objects and applied forces to reinforce understanding of net force calculations.
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to forces and motion in multi-object systems.
kathyt.25
"Three blocks (m1, m2 and m3) are in contact with each other on a frictionless, horizontal surface. A horizontal force is applied to m1.
http://i4.photobucket.com/albums/y111/kathy_felldown/sb-pic0556.png
What is the net force on block 1 and block 2?
What is the magnitude of the contact force between blocks 1 and 2?"
Fnet = ma
I found acceleration by calculating the Fnet = m(total)*a
a = 17.9 / (1.61 + 3.39 + 4.16) = 1.95m/s/s
Just for curiosity, I tried the Fnet (m1) = (1.61kg)(1.95m/s/s) = 3.14N and it was correct. I have no idea why the applied force, 17.9N is not considered in this... OR the force of m2 on m1 (according to Newton's 3rd law)
I also found the Fnet (m2) = (3.39)(1.95) = 6.61N. Why is it that the net force on each mass is simply equal to that object's mass * acceleration?
Also, I tried finding the magnitude of the contact force between m1 and m2. I figured that since the two forces are going in opposite directiosns, I should subtract Fnet(m2) - Fnet(m1) = 6.61 - 3.14 = 3.47N... but that is wrong!
Also for the contact force between m3 and m2, would the force acting on m2 be the applied force of 17.9N, or the net force that m1 exerts?
I can't view the picture you attached so I'm not positive about the orientation of the blocks. However, assuming I'm visualizing the correct thing, the net force on each mass is equal to that object's mass * acceleration essentially because it is defined that way. You first found the acceleration of the system which tells you that each block must be accelerating at that same rate as well (assuming I've visualized this correctly). Since, Fnet = ma, it follows that the net force acting on a specific block is ma. Hopefully this all makes sense.
To find the force of 1 on 2, we know that we applied 17.9 N of force to the first block, however, the net force acting on it was only 3.14 N. What does this suggest about the force of 2 on 1?
Again, since I haven't seen the picture, if none of this makes sense, just disregard it. Hope this helps.
The link doesn't work.
That's what Newton's 2nd law tells you: Fnet = ma. If you know the mass and the acceleration, you can immediately find the net force.
To use the net force to find the individual contact forces, you have to find the net force in terms of the individual forces. For example: F1on2 + F3on2 = Fnet_2.
Don't subtract the net forces. Subtract the contact forces (on m2, say) and set that equal to the net force on m2.
  • · Replies 17 ·
  • · Replies 16 ·
15K
  • · Replies 24 ·
10K
