Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image PDF and CDF manipulation Share It Thread Tools Search this Thread image
Old May28-09, 12:25 PM                  #1
S_David
S_David is Offline:
Hello,
I have this equation:
LaTeX Code: \\int_{-\\infty}^{\\gamma}f_X(x)\\,dx+\\int_{\\gamma}^{\\infty}F  _Y(x-\\gamma)\\,f_X(x)\\,dx
where LaTeX Code: f_X(x) and LaTeX Code: F_Y(y) are the PDF and CDF of the randome variables X and Y, respectively.
Now the question is: can I write the above equation in the form:
LaTeX Code: 1-\\int_{0}^{\\infty}(...)
Regards
Old May28-09, 02:48 PM                  #2
statdad
statdad is Offline:
Recognitions:
Homework Helper Homework Helper
Re: PDF and CDF manipulation
Try starting with
LaTeX Code: <BR>\\int_{-\\infty}^\\gamma f_X(x) \\, dx = \\int_{-\\infy}^\\infty f_X (x) \\, dx - \\infty_\\gamma^\\infty f_X(x) \\, dx = 1 - \\infty_\\gamma^\\infty f_X(x) \\, dx <BR>
Old May28-09, 03:17 PM                  #3
D H
D H is Offline:
Recognitions:
What statdad meant to say was: Try starting with
LaTeX Code: \\int_{-\\infty}^{\\gamma} f_X(x)\\,dx =<BR>\\int_{-\\infty}^{\\infty} f_X(x)\\,dx \\;- \\,\\int_{\\gamma}^{\\infty}f_X(x\\,)dx =<BR>1 \\,- \\int_{\\gamma}^{\\infty}f_X(x)dx
Old May28-09, 03:42 PM                  #4
statdad
statdad is Offline:
Recognitions:
Yes indeed, but statdad, in his advanced age, was interrupted by some annoying folks at the door and neglected to fix his post. Thanks.
Old May28-09, 03:52 PM                  #5
S_David
S_David is Offline:
Yes, but I want the whole right side be one minus single integral. Is this still doable in some how?
Old May28-09, 03:56 PM                  #6
statdad
statdad is Offline:
Recognitions:
Yes: you can write
LaTeX Code: <BR>1 - \\int_\\gamma^\\infty \\left(f_X(x) - F_Y(x-\\gamma)f_X(x)\\right) \\, dx<BR>
You should be able to take this and write it as
LaTeX Code: <BR>1 - \\int_0^\\infty ( \\cdots ) \\, dx<BR>
just play around with the integrand.
Old May28-09, 05:47 PM                  #7
S_David
S_David is Offline:
Originally Posted by statdad View Post
Yes: you can write
Thank you, but this form is not the one in my mind. I need, if possible, in some how, to eliminate the first term, so that the equation looks like:
LaTeX Code: 1-\\int_0^{\\infty}F_Y(a)\\,f_X(a+\\gamma)\\,da
Regards
Old May28-09, 06:07 PM                  #8
statdad
statdad is Offline:
Recognitions:
Look at the integrand in
LaTeX Code: <BR>\\int_\\gamma^\\infty \\left(f_X(x) - F_Y(x-\\gamma)f_X(x)\\right) \\, dx<BR>
You should see a very simple way to factor it and then rewrite it in a form more suitable to your desires for this problem.
Try it - do some work - then post again.
Old May28-09, 06:19 PM                  #9
S_David
S_David is Offline:
I can't see anything that I can do.
Old May28-09, 07:25 PM                  #10
statdad
statdad is Offline:
Recognitions:
Look a little harder. I won't give away the answer.
Old May29-09, 08:10 AM                  #11
S_David
S_David is Offline:
Just give me a hint, I am not strong in probability.
Old May29-09, 08:13 AM                  #12
statdad
statdad is Offline:
Recognitions:
Work with the integrand.
Old May29-09, 07:52 PM                  #13
S_David
S_David is Offline:
Are you sure that, we can write LaTeX Code: \\int_\\gamma^\\infty \\left(f_X(x) - F_Y(x-\\gamma)f_X(x)\\right) \\, dx as LaTeX Code: \\int_0^{\\infty}F_Y(a)\\,f_X(a+\\gamma)\\,da ?
image image
Reply
Thread Tools
Similar Threads for: PDF and CDF manipulation
Thread Thread Starter Forum Replies Last Post
Weather manipulation wolram Scepticism & Debunking 8 Aug29-08 10:09 PM
Tensor Manipulation bdm000 Special & General Relativity 3 Jun5-08 09:02 PM
Algebraic Manipulation unique_pavadrin Precalculus Mathematics 9 Mar3-07 05:54 AM
matrix manipulation in c tandoorichicken Programming & Comp Sci 1 Mar7-06 03:50 AM
Genetic manipulation caumaan Biology 1 Dec21-03 06:04 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
