Kinetic energy/rotational kinetic energy
The discussion focuses on the comparison of kinetic energy in two scenarios involving a rectangular object colliding with a ruler. In Case 1, the object strikes the ruler at its center of mass, resulting in only translational kinetic energy. In Case 2, the object strikes the ruler off-center, generating both translational and rotational kinetic energy. The conclusion is that Case 2 results in greater kinetic energy due to the conservation of both linear and angular momentum, allowing for the ruler to spin while moving forward.
  • Understanding of linear momentum conservation
  • Familiarity with angular momentum conservation
  • Knowledge of kinetic energy types: translational and rotational
  • Basic principles of torque and its effects on motion
  • Study the principles of rotational dynamics in physics
  • Learn about the conservation of angular momentum in collisions
  • Explore the mathematical formulation of kinetic energy in rotating systems
  • Investigate real-world applications of rotational kinetic energy in engineering
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of kinetic energy and momentum conservation in collisions.
reb659
Imagine two scenarios. The system in both is the object and ruler.
In case 1, a rectangular object undergoes a collision with a ruler, which is initially at rest. It strikes the ruler on its center of mass.
In case 2, it is the same situation except the object strikes the ruler in some point between its center of mass and the end of the ruler.
In which case does the ruler have greater kinetic energy and why? Explain in terms of conserved quantities.
The net torque and net force in both cases would be zero by the laws of conservation of linear and angular momentum.
I'm reasoning that the kinetic energy in case 2 would be greater because in case 2, both rotational kinetic energy and kinetic energy are conserved while in case 1, only kinetic energy is conserved.
Sorry about the bump, but I have an exam soon and an answer to question would really help me piece things together.
im going to give you my thoughts because you require some kind of answer now
this may not be correct, but it may help...so take it with a grain of salt...
case1:
there is a net force due to forward motion of ruler
there is a 0 net torque as the object strikes the ruler at its CG so there is no moment
and kenitic energy is present due to the forward motion of the ruler
case2:
there is a net force as the object strikes ruler a distance away from the CG of the ruler, so a moment is created allowing the ruler to spin
there is a higher kenetic energy in this case as the ruler is moving forward and spinning
hope that helps
  • · Replies 21 ·
  • · Replies 33 ·
