| Thread Closed |
Eigenvalues and eigenvectors |
Share Thread |
| May28-09, 01:44 PM | #1 |
Let A and B be similar matrices a)Prove that A and B have the same eigenvalues 2. Relevant equations None 3. The attempt at a solution Firstly, i dont see how this can even be possible unless the matrices are exactly the same :S |
| May28-09, 01:59 PM | #2 |
Recognitions:
So you think that eigenvalues uniquely characterize a matrix? What about
10 01 and 11 01 for example? You've put 'none' for relevant equations. That isn't true - there's a definition of 'similar' and many for 'eigenvalue'. Try it. HINT: polynomials. |
| May28-09, 02:00 PM | #3 |
EDIT: Changed "equation" to "polynomial"
You have to show that A and B=P^-1AP (for some invertible matrix P) have the same characteristic polynomial. |
| May28-09, 02:08 PM | #4 |
Oh, I think that way is much too complicated!
Do it directly from the equation: If [itex]Av= \lambda v[/itex] then, for any invertible P, [itex]P^{-1}Av= \lambda P^{-1}v[/itex]. Now define [itex]u= P^{-1}v[/itex]. |
| May28-09, 02:11 PM | #5 |
| May28-09, 02:16 PM | #6 |
or let [tex] Av = \lambda v [/tex]
then [tex] AP^{-1}Pv = \lambda v [/tex] and go from there |
| May28-09, 03:34 PM | #7 |
what do u mean by the same characteristic equation?
| May28-09, 03:53 PM | #8 |
EDIT: changed "equation" to "polynomial" The the characteristic polynomial of matrix A is [tex] det(A- \lambda I). [/tex] The characterisitc polynomial of matrix B is [tex] det(B - \lambda I) = det(PAP^{-1} - \lambda I) [/tex] so show that [tex] det(A- \lambda I) = det(PAP^{-1} - \lambda I) [/tex] But there are easier ways as HallsofIvy noted. Start with [tex] Av = \lambda v[/tex] where v is a nonzero vector then [tex] AP^{-1}Pv = \lambda v [/tex] since [tex] P^{-1}P = I [/tex] Do you know what to do next? |
| May28-09, 04:11 PM | #9 |
A and B are similar if and only if they both represent the same linear map, with respect to two possibly different bases. Eigenvalues are defined independently of what basis, if any, you choose. QED.
| May28-09, 04:12 PM | #10 |
Mentor
For it to be an equation, it at least has to have an equals sign. |
| May28-09, 04:52 PM | #11 |
| May28-09, 11:27 PM | #12 |
Av = lambda v
(AP^-1 P)v = lambda v Bv = lambda v i think? |
| May28-09, 11:28 PM | #13 |
oh wait....B = P^-1 AP .....so what i said is wrong...
how can i manipulate A P^-1 P to look like P^-1 AP? |
| May29-09, 12:07 AM | #14 |
ohhh i see...
since they can have the same eigenvalues, does this mean that the matrices can also have the same eigenvectors? |
| May29-09, 12:12 AM | #15 |
| May29-09, 01:22 AM | #16 |
I just tried several similar matrices but they all share the same eigenvector O.o
Can i get an example where two similar matrices have different eigenvectors? |
| May29-09, 06:50 AM | #17 |
I'm surprised you were able to find similar matrices that had the same eigenvectors!
[tex]A= \begin{bmatrix}2 & 0 \\ 0 & 3\end{bmatrix}[/tex] has, obviously, 2 and 3 as eigenvalues with corresponding eigenvectors <1 0> and <0 1>. [tex]B= \begin{bmatrix}1 & -1 \\ 2 & 4\end{bmatrix}[/tex] has the same eigenvalues with corresponding eigenvectors <1, -1> and <1, -2>. All I did was start with the obvious diagonal matrix, A, choose a simple invertible P: [tex]P= \begin{bmatrix}2 & 1 \\ 1 & 1\end{bmatrix}[/tex] and calculate [itex]B= P^{-1}AP[/itex]. |
| Thread Closed |
Similar discussions for: Eigenvalues and eigenvectors
| I don't get Eigenvalues or Eigenvectors | Linear & Abstract Algebra | 29 | ||
| eigenvalues and eigenvectors | Calculus & Beyond Homework | 5 | ||
| Eigenvalues and Eigenvectors | Advanced Physics Homework | 2 | ||
| eigenvalues and eigenvectors | General Math | 2 | ||
| Eigenvalues and Eigenvectors | Linear & Abstract Algebra | 23 | ||
