Proving 0 is Limit of x^2-4 as x→2 via Epsilon-Delta Def.
  • Thread starter Thread starter JG89
    Limit
The problem involves proving that the limit of the function x² - 4 approaches 0 as x approaches 2, using the epsilon-delta definition of a limit.
  • Participants discuss various methods to establish a suitable delta in relation to epsilon, including specific values for delta and the use of the triangle inequality. There is a focus on simplifying the proof by making assumptions about the size of delta.
Several participants have provided insights and alternative approaches to the problem, suggesting different ways to handle the epsilon-delta relationship. There is an ongoing exploration of assumptions and simplifications without a clear consensus on a single method.
Participants note the importance of choosing appropriate bounds for delta and the implications of these choices on the proof's structure. There is mention of specific constraints such as assuming |x-2| < 1 to facilitate the proof.
JG89
Prove using the epsilon-delta definition of a limit that 0 is the limit as x approaches 2 of x^2 - 4
I've never actually done a limit proof like this before, so I just want to make sure that it's correct.
[tex]|x^2 - 4| = |x-2||x+2| < \delta |x+2|[/tex].
We can restrict the size of our delta-interval small enough so that for a fixed quantity c, [tex]\delta < c[/tex] and 0 <= 2 - c. Since [tex]\delta < c[/tex] then [tex]2 - c < 2 - \delta[/tex] and [tex]2 + \delta < 2 + c[/tex], and so [tex]2 - c < x < 2 + c \Rightarrow |x + 2| < |4 + c|[/tex], and so [tex]\delta |x+2| < \delta |4 + c| = \epsilon[/tex] and taking [tex]\delta = \frac{\epsilon}{4+c}[/tex] shows that we can always find a suitable delta such that for each epsilon > 0, |x^2 - 4| < epsilon whenever |x-2| < delta
How's this look?
If you are going to restrict delta, you might as well pick a specific value. For instance, we can suppose delta is less than or equal to 1 so that |x-2| < 1 implying 1 < x < 3 so 3 < x + 2 < 5 and |x+2| < 5. Then we have d|x+2| < 5d. Letting d = min{1, e/5} works.
Or, you can also note that |x+2| = |x -2 +4| =< |x-2| + 4 by the triangle inequality. Then you need d(d+4) = e, so you can use the quadratic formula to find delta as a function of epsilon.
true, but you can assume c=1 (that is |x-2|<1 ) at the first place to simplify the proof. (so that |x-2||x+2|<5|x-2|<e, if |x-2|<e/5 )
snipez, I like your second method of finding a suitable delta. Thanks!
In order to assume |x-2|< 1 you must say [itex]\delta[/itex]= min(1, [itex]\epsilon[/itex]/5)- the smaller of the two numbers.
  • · Replies 31 ·
  • · Replies 26 ·
